MrSkippyJ Posted February 7, 2010 Report Posted February 7, 2010 Bass Knob will Cook your woofer. So can a gain knob. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Decaf Posted February 7, 2010 Report Posted February 7, 2010 this is simple bass knob = its just an eq boost like on your cd player centered at 45hz or a variable frequency u can choose (35-70hz lets say), not a good choice because u arent boostin every note nor when u turn it down are u quieting all notes because the boost has a slope on each side like a crossover point... this is called the q (for those of you with parametric eqs u should know this!) so even if u boost at 45hz there will still be boost at 40hz and 50hz for example remote gain/level knob adjust the input senstitvity of the signal the amp recieves.... meaning it will alter all notes the amp plays... this is what u want because it is more precise/more predictable/more reliable (sundown, aq, some dd, upper end hifonics) both can be dangerous if u arent familiar with ur system and the sound of ur subs under stress beyong its capabilities both thermally and mechanically
MrSkippyJ Posted February 7, 2010 Report Posted February 7, 2010 both can be dangerous if u arent familiar with ur system and the sound of ur subs under stress beyong its capabilities both thermally and mechanically Thank you. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
R_Mac_1 Posted February 7, 2010 Report Posted February 7, 2010 So...is there a way to know which you have? Because my el-cheapo Profile AP1000M has a bass knob that I guess I always assumed was a gain knob, but it could be boost I guess. The manual calls it a "bass level remote control." 2002 Pontiac Bonneville SSEi Pioneer DEH-P6000UB Alpine SPX-17REF 6.5" components (active) Sundown SAX-50.4 Sundown z15 (3 cubes @ 35 hz) Sundown SAX-1200D 2006 Buick Rainier CXL AWD V8 Stock Bose system 12" Alpine Type E in aeroported box Profile AP1000M
STEvil Posted February 7, 2010 Report Posted February 7, 2010 If you popped open the amp you could use a digital multimeter to measure the gain circuit as you adjust it (not while its on or playing) to see which one it controls. Thats about it if the manu is crappy enough not to tell you exactly what its for. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
R_Mac_1 Posted February 7, 2010 Report Posted February 7, 2010 From the manual: bass level remote controlModels XXX, XXXX etc are equipped with a wired bass level remote control that can be mounted under dash to remotely control the level of the bass 2002 Pontiac Bonneville SSEi Pioneer DEH-P6000UB Alpine SPX-17REF 6.5" components (active) Sundown SAX-50.4 Sundown z15 (3 cubes @ 35 hz) Sundown SAX-1200D 2006 Buick Rainier CXL AWD V8 Stock Bose system 12" Alpine Type E in aeroported box Profile AP1000M
