If it was a 2 channel amplifier and a crappy one, maybe.
If your ohm load is greater than the lowest rated ohm load of the amplifier then in general you are safe for monoblock amplifiers. For bridged stereo amplifiers you need to double the ohm load (4 ohm single coil appears as 2 ohm single coil to a bridged stereo amp).
There's a bit of leeway though due to impedance rise (box type, coil temperature, number of coils, average coil movement, frequency.. etc).
Edited by STEvil
Hammerdown... 1%
not even close.
if it was less than the minimum impedence probablybut in this case no
not at all
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
i heard that if you hook up a sub at 2.66 ohm to a 2 ohm amplifier, u will wreck the amplifier
is this true?
No!
Lack of voltage and increase of current equalling excesive heat build up will damage an amp but if you are running above the recommended ohm load it is always a good thing as far as how stable the amp will run.
Had to change voltage and current. Sorry.
Edited by ISO
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Completely WRONG!!!
TDH FTW !!!
Very educated responce!
93' Ford Aerostar
Alpine head unit
4-5.25 MB Quarts
20-10" pyramids super Pro
1 Lanzar amp
  • Who's Online   0 Members, 0 Anonymous, 1399 Guests (See full list)
