kicker99chevy Posted February 15, 2010 Report Posted February 15, 2010 ok id like some input on this i got 2 15in lvl 5 dual 1 ohm subs but undecided on what amp id like was thinking the soundstream xxx6500 or to much XXX10000D if thats possible i think thats to much id like to get just 1 amp but if i need to ill get 2 my electrical is good bigger alt and iv got 5 hc2400s so id like input on what would be the best choice somewhere around 1400 is the most i can spend
troy Posted February 15, 2010 Report Posted February 15, 2010 well first of all your gonna see some weird ohm load bc of 3 subs unless you get custom coils so make sure you take that into account. also if your not gonna give each at least 2500rms id go with a different choice even though they are rated at only 2k. retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
treossi Posted February 15, 2010 Report Posted February 15, 2010 i wouldn't go with sound stream amps, they don't make rated power unless you're running 16+ volts, you should check out dc power engineering about your alternator though Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
sound xtreme Posted February 16, 2010 Report Posted February 16, 2010 as long as you have the electrical to back it up, the SS amps work well. If you are interested in a SS 10K, PM me, can hook you up cheap 1997 Astro front:6 sets of T3 componets Subs: 8 level 5 18"s (building 6th order BP) Amps: 4 really big ones (totalling just shy of 50K) Batts: Alt: Ohio Generator 1996 Chevy Suburban Sub amp: A fifth really big amp Subwoofer: 2-15" DC Level 4 XL Batts: C&D high rate--(x4)
uhoh_45 Posted February 16, 2010 Report Posted February 16, 2010 well first of all your gonna see some weird ohm load bc of 3 subs unless you get custom coils so make sure you take that into account. also if your not gonna give each at least 2500rms id go with a different choice even though they are rated at only 2k. wow reading > you as for an amp look into soundigital R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Destram Posted February 16, 2010 Report Posted February 16, 2010 i wouldn't go with sound stream amps, they don't make rated power unless you're running 16+ volts, you should check out dc power engineering about your alternator though He said he has a "bigger alt." 2006 BMW 325i My feedback: http://www.stevemeadedesigns.com/board/topic/77301-official-destram-feedback/
Bills Posted February 16, 2010 Report Posted February 16, 2010 i'd say a big one.....lol, na I ran my 2 lvl 5 15" subs on 2000w each, 3kw, and 5kw, out of the three, the 3kw was the worst because of the amps I was using. Very power hungry and not clean power. Look for some good efficient amps that are rated atleast 2kw at like 12v. trust me, i went through the whole buying an amp that does its power with like 14..4 volts but won't come close after voltage drops to mid 11's at full tilt Bills KwB Team DC Audio Midwest captain
AI James Posted February 16, 2010 Report Posted February 16, 2010 i'd say a big one.....lol, na I ran my 2 lvl 5 15" subs on 2000w each, 3kw, and 5kw, out of the three, the 3kw was the worst because of the amps I was using. Very power hungry and not clean power. Look for some good efficient amps that are rated atleast 2kw at like 12v. trust me, i went through the whole buying an amp that does its power with like 14..4 volts but won't come close after voltage drops to mid 11's at full tilt Bills agreed, all you need is 2krms dont need nothing more unless you make the wrong box
18inchjeepin Posted February 17, 2010 Report Posted February 17, 2010 sounds like you got the electrical part down yes the ss amps will work, I ran 1 6500 on 3 batts and stock alt in my jeep, worked fine HHR (2) 15 DC Soundlab Lvl4XL SPL's (1) Soundstream XXX-15000D (9) XS Power D1000's XS Power - Soundstream SS N/W 155.1 db and climbing
