Testing DC 3000.1s vs Sundown SAZ3500s
Noobtastic14
I know someone who does
Of course Jacob! I believe that the 3500s have gained quite a bit since our last run on the meter/testing and am just posting results as I go. Our next tests will be replicating the unloaded tests with clamp and TL then doing some tests loaded to calculate rise and total output.
-Drew
uhoh_45 said:
with my crappy clamp meter right around where i bassrace just playing a 40hz tone instead of 37hz juice box...
heres the numbers and they are close enough between the pair that ill just use the "left amp"
320A DC draw
13.2V (car running both amps full tilt on a tone)
speaker output side; 17.3A and 82.0V
i wasnt running the clampmeter on the output side...so im taking them with a grain of salt.... :rolleyes:
but if the numbers are right i should have like 1400ish watts with rise at 4.7ohms per amp from .65
that is a problem... who does 54 bassrace with 2800W :o
im going to put the dc amps in and see what they do again in the same setup just a drop in. also going to wire all the subs on one amplifier and check total rise....
i dont think a 12000W amplifier will do much at 8ohm.
DCAUDIO
BALLS DEEP
  • Who's Online   0 Members, 0 Anonymous, 782 Guests (See full list)
