not to thread jack but why's everyone elses version of this calc have the port bends button? was there an updated version i have to download? anyway back on topic, new design looks much better
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
sorry for double post.
jst mess around abit more. hope this one look better then the first.
re box cal. if this good port for the sub i will be going this one.
PS box is going chevy s10 ext cab.
thanks
-chris
port area is still way too small, use this site to help you figure out your minimum port area for that sub:
http://www.carstereo.com/help/Articles.cfm?id=31
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
i beleve there was an update.
ok i done that..
i get Minimum Diameter 13.23in
Minimum Area =137.44in
Length of a side
for a square vent =11.72in
i am think i have to come up with 137.44ish for the box port area. right??
sorry for so much questions. im learing nd every help will appratade.
ok i done that..
Length of a side
since you're not doing a round or square port, you can ignore the diameter & length for a square vent...
right, you would have to come up with at least 137.44sq.in.(@32hz) of port area to avoid port noise....
ok sound good.
im play around more with torres cal. nd if i come up with something good ill post it up again. to verify if it correct.
thanks so much guys.
-CHRIS
having a port THAT thin WILL cause port noise. make the port ratio smaller than 1:8 (1" by 8" or 2" by 16" or 3" by 24" etc etc. smaller would be 1 by 7 or 2 by 14 or 3 by 21, those are 1:7 ratios)
first jst wanna say big thanks to the people who are helping me out!!!
got some qestions.
what in blue. tune i want 34hz but torres cal. say 36hz?
what is in red. very close to port size cal. (146.03) nd torres cal. is (146.25) with this number it is tune to 34hz correct?
one more question i see a ( - negitive number) could this mean bad??? what circle in yellow.
thanks so much!!!
-Chris
ps i change the height of box so the port can clear the top part of the sits.
got some qestions.
thanks so much!!!
-Chris
make your port longer til it hits 34hz or make your port area bigger for 36hz...
146.25 is ok, 146.03 is just your minimum @34hz...
not sure what the negative number could mean...???
just keep playing with it, til it all falls into place...
got some qestions.
thanks so much!!!
-Chris
Ya a negative port length would kinda be impossible. at the bottom of the page in the background you can calculate ideal port length.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
  • Who's Online   0 Members, 0 Anonymous, 1137 Guests (See full list)
