will thise cause a issue powering a system???
Edited by ROCKSOLID84
JAMES SAID..
you dont need 1500 for a WOOFER people just love overpowering rather then building for the power recommended
THATS A SMART GUY...
what batteries?
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
what batteries?
its a compatability question size should not matter...
JAMES SAID..
well he wasn't asking about the size...and as long as the wet cells are not inside cabin.
RE se xxx 18d2 (4)
Audioque 2200 (2)
DC Power 270XP blue
3 C&D fr310
Stinger wiring
CDT components
As a rule, I never mix wet and dry. Bad things can potentially happen when you mix them.
elaborate please
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
ive done it before
i wouldnt again tho, sometimes they charge a different rates and discharge at different rates
this makes it very hard to keep both batts at the same voltage when one will always be drawin current from the larger one
in a perfect world ud have the same batts under the hood as in the trunk
The flooded ones almost always float at a lower voltage than dry cell (assuming you mean gel or AGM) so there's always a small trickle of current running from the dry to the wet. In theory it will run the battery flat after a while.
10.x volts fo' life!
well yea you guys are right about the wet drawing from the gels. but only in a perfect world can you use the same kind of batts in the rear as the front. alot of cars only have room for a small wet cell in the front. plus some peoples budgets may not allow for an extra gel cell to go in the front. just a thought is all
  • Who's Online   0 Members, 0 Anonymous, 642 Guests (See full list)
