Hotdog Posted March 9, 2010 Report Posted March 9, 2010 Is there pro or cons on 3" vs 4" voice coils? If I were shopping for some subs... is it better to get the larger voice coil? Does larger voice coil mean more power handling? Can some one break this down for me thank you 4" Voice Coil (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
PONCE2006 Posted March 9, 2010 Report Posted March 9, 2010 Is there pro or cons on 3" vs 4" voice coils? If I were shopping for some subs... is better to get the larger voice coil? Does larger voice coil mean more power handling? Can some one break this down for me thank you IVE ALWAYS THOUGHT OF BETTER EXCURSION OF THE SUB.
mr.p Posted March 9, 2010 Report Posted March 9, 2010 damn dude is yellin.. 4" coil would be a higher power handling subwoofer depending on the layers of the coil and material and winding size and all that stuff vs the same in 3" DCAUDIO BALLS DEEP
Nirvalica Posted March 9, 2010 Report Posted March 9, 2010 If u notice a lot of SQ drivers usually have huge voice coils. Some examples are some dynaudio equipment and morel. Not really sure what the size has to do with it, maybe better sensitivity or something... But usually spl subs with bigger voice coils can handle more power. My Youtube Page. Check it out The "SAV" - Sub-aural Assault Vehicle Kenwood eXcelon KDC-X993 Image Dynamics CTX 6.5" Components Q-logic 6.5" kick pods CDT 6.5" CL-E6NEO Front door Midbass Kicker ZX350.4 Knukonceptz SS Karma 4 channel 6m RCA Fi Q 18" w/ brushed aluminum dust cap 7cu ft. ported box tuned to 28hz Sundown SAZ-1000D Iraggi 240 amp Amputator Alt Big 3 in Monster 1/0awg Second Skin Damplifier Lite on roof and front doors
Guest Posted March 9, 2010 Report Posted March 9, 2010 damn dude is yellin.. 4" coil would be a higher power handling subwoofer depending on the layers of the coil and material and winding size and all that stuff vs the same in 3" not true for RF's Power series woofers 1000rms for a 4". last gen i think was 600rms.
uhoh_45 Posted March 9, 2010 Report Posted March 9, 2010 power handling and cooling the bigger the coil the longer it takes to heat up R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Hotdog Posted March 9, 2010 Author Report Posted March 9, 2010 not true for RF's Power series woofers 1000rms for a 4". last gen i think was 600rms. some last Gen are 1000rms on a 4" Voice coil also.. Check my signature. RFR2212 & RFR2215 models were 1000rms 4" Voice coils. (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
Hotdog Posted March 9, 2010 Author Report Posted March 9, 2010 power handling and cooling the bigger the coil the longer it takes to heat up So one of the Pro's that a 4" coil has over a 3" coil is it cools better? (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764
zfrerichs Posted March 9, 2010 Report Posted March 9, 2010 bigger is not always better. it depends on the driver your looking at, to me there are only a few drivers that actually need a 4" coil lvl 6 tsns shw GZ plutonium just to name a few all of these coils have large windings and are meant to take power. not like mtx 9500s and rf t2s Roseville, CA
wL<3bass Posted March 9, 2010 Report Posted March 9, 2010 3" Coils usually have less moving mass and yield better results for lower power or for burping where heat isn't a concern, if you want a high power sub for daily a 4" generally would be a better coils. Hence why the SMD uses a 4" coil. Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
