What are pro vs con on 3" vs 4" Voice coils?
Hotdog
bigger is not always better.
it depends on the driver your looking at, to me there are only a few drivers that actually need a 4" coil lvl 6 tsns shw GZ plutonium just to name a few
all of these coils have large windings and are meant to take power. not like mtx 9500s and rf t2s
So are 4" coils also longer then 3" coils? and I did not under stand the not like mtx 9500s and rf t2s part... are you saying that they could have used a 3" coil and stayed in the same power range?
Yes... having a 4" coil just increased the Mms when a 3" coil would have been cheaper and yielded better results and still maintained power rating and durability.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
So is the power rating mostly based on the coil?
Say you want to run 1000rms to 1 sub.. you can get that with a 3" coil?
and will the sound quality differ any between a 3" and 4" coil on 1000rms?
Power rating is based on wire gauge, wire material (copper, aluminum), quality, winding width, surface area to dissipate heat, motor cooling, etc... There's alot more to it then just size.
The mtx9500 and RF T2 could have easily gotten away with a 3" coil like I said. The SQ of a driver is dependant on ALOT of things.
My YouTube Videos
the main reason to go with a 4" coil over a 3" is 4" coils are usually used with SPL oriented subs like zdifetz said up there those subs are ment to be burped on 20-40 Kw
where an mtx 9500 and RF with 4" coil can be burped on like 5-6 k tops?
most those subs arnt ment for daily because it takes so much power to get them to there max potential
so thats why you dont see many daily subs with 4" coils
R.I.P!
(Nov-29-2009)
92 explorer
current build
3" coils typically are much more efficient in SPL application but when a 3" coils limits are reached a 4" coil is often used along with a much larger motor to help accommodate the extra Mms.
Daily drivers such as the SMD runs a 4" coil for daily b/c it is an extremely high power driver made for music on 4kw+ for sustained periods (more than 30seconds)...
My YouTube Videos
What are the RMS Limits on a 3" coil and a 4" coil? and how much does the motor play in determining the limits of each coil?
Don't mean to ask so many questions but it will be great for more people to read when looking for subs and how to determine how to make choices.
So many aspects between the 2 sizes
the majority is right cooling, but you can make a cooler running coil with other features, like the Fi and DD cooling techniques by machining the pole pieces, and top plates to allow extra air cooling, or aluminum heat sinks
on coils the majority of cooling is winding area and the former helps A-LOT as well, when its aluminum, titanium or stainless, it helps suck the heat from the coil wire, and disperses the heat to the dome/cone, also the heat radiates to the top plate, and pole piece as well.
The disadvantages to 4" coils is the weight of the coil, how it effects the parameters of the speaker. Typical aluminum coil is about 3 times what a 3" coil is. And when you go to copper, well, a copper 4" coil will weight about 6-10 times what a typical 4" coil weighs
This picture here,
shows a HX2 Power 4" coil far right, its copper
Middle is a TRF coil, just a 4 layer flat aluminum on aluminum former
and a bi-filar 4" on the left ( 2 wires ran down the former when making the coil )
The HX2 coil is copper round wire, with 2" of winding width/height, while the TRF is 2.3" , and the 3rd on the left is 2.8" ww
The weight of that copper coil weighs A LOT, so it brings the efficiency of the woofer down a lot
This just shows some 4" coils next to 3" coils
forgot to mention, usually a 4" coil needs more power to get it to the same output as a 3" coil
also besides power handling being based on cooling, and coil size, actually suspension plays a big part in the mechanical part of power handling
if you have a cone with a soft suspension, and a single spider, yet a strong motor/coil, and when you hit that woofer with some real power, that coil will want to shoot right out of that motor, and sometimes literally rip apart
thats why these woofers that do handle tons of power, usually have very stiff suspensions, multiple spiders, etc etc
hey bumpin do they make 3.5" coils?
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 2479 Guests (See full list)
