chewie Posted March 23, 2010 Report Posted March 23, 2010 try and reline the spider up as good as possible and check for coil rub before you glue it.. you could try and pop the duscap off and recenter it. 91 dodge colt gt.. 4 custom t600 15s audioque 3500d.1 tuned to 25 hz... stay tuned. blazer stroker 15 brutus bxi2006d terrible voltage drop 145.4@38HZ... SEALED LEGAL Aim: chewieft09 www.t3audio.com carpe diez nuts !! my house is louder than your car...
IH8PunkRok Posted March 23, 2010 Report Posted March 23, 2010 impatient.. most likely if you try to reglue it, it wont be aligned right and will rub. you may get lucky and itll work perfectly. if you dont think itll work out just send it in for a recone -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Guest jbinn Posted March 23, 2010 Report Posted March 23, 2010 Well the sub is brand new, this wouldnt be covered? isnt it a mechanical failure/ im not buying a recone for a $134 subwoofer lol but I also don't want to waste my warranty by trying to repair it, but I guess I'll just have to try
IH8PunkRok Posted March 23, 2010 Report Posted March 23, 2010 ask them if its covered. if it is send it in. if it isnt try to carefully repair it. if that doesnt work then just buy a new sub man. -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Colin - STAPUFT Posted March 23, 2010 Report Posted March 23, 2010 x2 on the warranty. See if they will cover it. If not, get some CA glue. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=340-620 I had two do the same thing but it was ALL my fault. I had one do this: And one did this: I used the CA Glue in the link. I just cleaned the debris from the gap and lined them up as best as I could. No issues since. Worth a try. 12 - 12"s in the STAY PUFT 1989 Chevy Astro Build & Comment Log Un-Interrupted Build LogYouTube Channel Chevy Trailblazer 5.1 Dolby Digital DTS Install You have a beard of a mysterious sea captain. I would follow you to hell and back.
Guest jbinn Posted March 23, 2010 Report Posted March 23, 2010 I wouldnt mind buying a new subwoofer if I was made of money... this thing is 1 week old wtf? and it wasnt even my fault at all so yeah this is bs if they dont cover it.
Guest jbinn Posted March 23, 2010 Report Posted March 23, 2010 x2 on the warranty. See if they will cover it. If not, get some CA glue. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=340-620 I had two do the same thing but it was ALL my fault. I had one do this: And one did this: I used the CA Glue in the link. I just cleaned the debris from the gap and lined them up as best as I could. No issues since. Worth a try. What do you guys mean by lining them up? dont I just put glue on the spider ring and hold it down onto the gasket? what do you mean by lining it up
Guest jbinn Posted March 23, 2010 Report Posted March 23, 2010 it happens when ya buy junk though i have a Fi I know what sjunk or not lol , this subwoofer is fine other than the spyder maybe it was getting too much excursion i dunno... point is, i need to fix it not know why it happened lol
Sanitarium Posted March 23, 2010 Report Posted March 23, 2010 If you can't get it warranted, carefully cut the dustcap off and shim it up with some cardstock from the inside before glueing
