95 civic. I have horrible engine noise with or without ground loop isolator. Worse without isolator. Tried groundg rca shield to radio, chassis, battery. Tried power line noise filter. I get interference with car ignition switch on, but without motor running. If i turn blinkers or hazards on, I hear it through the speakers. If i crank car it is much worse, almost like 2 different noise sources. Unplug rcas from head unit noise is still present. If i insert a mute plug in rca, the noise is gone. This is with three different amps, new and used. When i grounded the rca shield to the radio, it gets worse. Part of the noise seems to come from the fuel pump under the back seat. If i get the wires away from it, it reduces it, but not enough. Help!!!
God damn its hot today. My balls are stuck to my leg.
i remember reading a few days ago, that where the speakers where screwed into the door, was causing the engine noise cause it was acting like a ground r some shit ..:/
just a thought ... are the screwed to the sheet metal in the doors?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
did you try a different hu? Are speakers run off amp or hu? Maybe try replacing rcas
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
speakers are on a 4 channel amp. No rears only front. Fronts are mounted to a wooden plate to keep from hitting window. It is a Pioneer radio, but I get the noise with rcas unhooked from radio. Tried different head units, different amps. I have gone through every noise troubleshooting checklist I can find. I tried isolating the switched power lead from vehicle with a relay. No help. Had noise with factory alternator and HO alternator.
Has each different HU you tried been different than a Pioneer? Pioneers are notorious for the engine whine...
12" DC LVL 4
Sundown 1200D
PG RSDs
PPI PC2100
Alpine 9886
  • Who's Online   0 Members, 0 Anonymous, 737 Guests (See full list)
