Boon Posted March 25, 2010 Report Share Posted March 25, 2010 necessary? not really. but safe? yes That's like saying is any fuse at all necessary (by the way Navi, fail post...) If you only use 1 fuse you may as well use no fuse at all. It's either 2 fuses or nothing. The reason being that if you get a short in the middle of the wire the fuse by the front battery will blow but because you didn't fuse the back battery as well it will proceed to dump 1500A through your cable and set your car on fire. I don't know a lot of cars that cost less than $5, and that's what a 250A fuse costs. You do the maths. Quote 10.x volts fo' life! Link to comment Share on other sites More sharing options...
mbdblue Posted March 25, 2010 Report Share Posted March 25, 2010 That's like saying is any fuse at all necessary (by the way Navi, fail post...) If you only use 1 fuse you may as well use no fuse at all. It's either 2 fuses or nothing. The reason being that if you get a short in the middle of the wire the fuse by the front battery will blow but because you didn't fuse the back battery as well it will proceed to dump 1500A through your cable and set your car on fire. I don't know a lot of cars that cost less than $5, and that's what a 250A fuse costs. You do the maths. I stand corrected Quote AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
Red-navi-916 Posted March 25, 2010 Report Share Posted March 25, 2010 (edited) I guess over the years and systems 4+batts my way never failed me so it's your word against mine...............I'm not a know it all but I can tell you what I do know and try to help when I can. God damn itouch Edited March 25, 2010 by Red-navi-916 Quote BUILDLOG http://www.stevemeadedesigns.com/board/ind...showtopic=61862 "98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!! Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass. Link to comment Share on other sites More sharing options...
moh.vze.com Posted March 25, 2010 Report Share Posted March 25, 2010 So if one has a big 3, it would be 1 fuse from batt under hood to the alt and then another fuse from batt under hood to another fuse and to batt in trunk. Then you got another fuse from that bat in the trunk to the amp. 2 bigol fuses under the hood takes up a lot of room Quote DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs Link to comment Share on other sites More sharing options...
tdsa23 Posted March 25, 2010 Author Report Share Posted March 25, 2010 ok so see where i get confused, 2 replies saying two different things. Is 2 fuses between the front and back B+ really necessary? When I called XS Power they said I should put a fuse on both ends and for a better connection run ground wire from the fron to back but thats money I dont have right now so could I just ground it to the back for now? Quote XS Power D5100, 2 D2700s, & 2 D975s MechMan 220a Alt DC 5K Kicker 650.4 2 12 Ascendant Audio Mayhem's Pioneer DEH-P7200HD Rockford Fosgate 3sity.1 Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899 https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/ Link to comment Share on other sites More sharing options...
mbdblue Posted March 25, 2010 Report Share Posted March 25, 2010 also you can either ground it on the chassis or run a negative...some people prefer to run a negative so they have a good connection. Quote AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
cvxsmitty58 Posted March 25, 2010 Report Share Posted March 25, 2010 i run 0 ga front to back fused on both ends. havnt had a problem with it. Piece of mind that my car wont set on fire is worth the 20 bucks. Quote Link to comment Share on other sites More sharing options...
