So I threw my Hifonics 12's in a ported box, and I smell burnt/burning coil all the time now. Unless I turn it down to the point they aren't moving any air. Burned CDs, radio, bought CDs... no matter what I smell coil. They are still bumping and no change in resistance. Any ideas???
Thanks,
Matt B)
What amplifier are you running?
Mids/Highs: stock Bang & Olufsen
Lows: Image Dynamics IDMax 12v.3
Power: Sony Xplod XM-D9001GTR:Knukonceptz 4 gauge
Box: 1.75 cu/ft Sealed
Past: Pioneer Premier TS-W1207 (2)/ Rockford Fosgate P210/ Image Dynamics ID10V.3/ Infinity Reference 311A/ Audiopipe AP-18001D
clipping ..... playing below tuning.
whats your setting on your amplifier?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Its the Massive Audio Nano Block N2 (800w RMS). Gain I believe is below half now, I was turning it down as I was driving. Box is tuned to around 32hz. about 1.5 cubes per sub with a 2in pvc port for each.
Thanks
what are your head unit settings as well.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I'd run more port area.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
for one, stock HUs almost always have a horrible output curve... no flat response at all out of the speaker leads...plus your "bass" level is negative... the stock EQ in the HU doesn't ever have a smooth slope to change the frequency levels... add that to a line output converter... that degrades the quality of the already crappy signal even more... especially ones with adjustable levels.
you understand that you may have set the gains correctly at one frequency but they could be totally jacked up at another? and that frequency could be clipping the shit out of the amp.
i'd recommend a head unit with good 4v RCA preamp outputs, and a good set of RCAs. i've personally never had problems with Stinger and Knu RCAs... but that's just me.
get a decent aftermarket HU, run good RCAs, set the gain again, call it a day.
you'll notice a huge improvement over stock audio quality... and i assume you're running the bass down on your HU because at high volume it over powers your speakers in your car?
A decent HU has a high pass filter on it... that does exactly the opposite of what a low pass filter does... it takes the bass below a certain freqency (usually 80Hz or 120Hz) out of the speaker's signal.
Just my $.02
Well I was holding off on the aftermarket headunit. I was going for a sleeper look.
Guess I'll start looking for a headunit. I threw a Audiobahn 15" in and there wasnt any smell though?
That's why I was confused. Any ideas on how to set the gain on the Hi-Lo converter for the time being?
Thanks Again guys
Thanks Again guys
Just to take a stab... I'd say make the Hi-Lo converter "gain" at like 75%.. same thing with the deck up front.. leave the EQ flat or off... then set the gains with a DMM.
And I totally understand the sleeper look. You really want a sleeper look.. get a 3.5mm - RCA adapter.. use a Walkman cassette player as your head unit......lolol
  • Who's Online   0 Members, 0 Anonymous, 8091 Guests (See full list)
