So Im going to drill through the firewall in my caddy to wire up my OLD Visonik subs just because I cant stand having no bass at all (temporary until I get a new job and can afford the DC Audio subs), would this be a good area to drill through? I was going to drill underneath the wires (bout 1 inch lower) but for all I know there could be 2 layers of metal and something important in between them and I obviously dont want to drill into anything other than metal.
Inside the car
Engine bay
This is on the far passenger side
Edited by Velvetdreams21
1993 Cadillac Fleetwood Brougham.
Jensen UV10 DVD HU
Two 12" Sony Xplode (temporary)
drivers side. clutch knock out panel.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
yes this or look for drain plugs
I know a lil about everything so dont call me Mr. Know it All.
i want to try and keep everything on one side of the car otherwise Im a bit worried I wont have enuf wire. The battery and the area easily acessible to the trunk behind the seat is on the passanger side
Drain plugs? Sorry, dont know a whole lot of what to look for
or drill right above those wires, since it is easily accessable and there isnt anything there.
You sure there is nothing above? I havent really looked yet, can anyone confirm?
No offense at all man, I just want to be damn sure before I go drilling into things
Jensen UV10 DVD HU
well just make sure there is NOTHING in the way.
if you used the drivers side u can pass the power cable thru the hole that is used to get the "hood unlache" wire thru to the outside/inside.
on the driver side look for the hole used to run the AC lines, thats what I used....
hope this helps GL!
Ok Im sure a lot of you will facepalm with this question but its been a long time since Ive hooked one of these up, on the Audio cables that run from the HU to the amp, whats this third wire again?
hope this helps GL!
I just fear I wont have nearly enuf cable otherwise I would definitely do it. I just barely had enuf cable when I hooked it into my bonneville and the caddy is longer
Jensen UV10 DVD HU
3rd wire would be remote I believe. You have your RCA's and then remote to turn on your amp. I don't know about the drilling though. Good Luck to you.
1989 E30 325i BMW (New Car)
iPad 64GB 3G (COMING SOON!)
1 12" DC LEVEL 4 w/LEVEL 5 Soft Parts
Ported box - 1.5 Cubes tuned to 33hz
Sound Stream STL1.1200D
4 Gauge Stinger Wire (+ & -)
8 Gauge Amp to Sub Stinger Wire
Tsunami Mini ANL 130 Amp Fuse
AUDIO WRAP SUPPORTER!
should be remote turn on
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
I don't know what year model caddy you have.. I have a 94 Sedan Deville though. I went through passenger side floor board, because the battery was mounted on the passenger side of the car.. 14 foot run to the trunk. Wasn't too terribly bad.
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
  • Who's Online   0 Members, 0 Anonymous, 951 Guests (See full list)
