Idk what kinda car or enclosure you have but maybe the enclosure? Or under the seat (like Steve, that way it won't fall)
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I thought mounting on the enclosure is bad for the amp.
Mounting it to the box with a sheet of Secondskin between the amp and box should be fine but a general rule is to avoid it in the first place.
Edited by ATLien
my dad had his fosgate amp mounted on his enclosure without problems but his setup was weak. What kind of car do you have, that would help answer your question.
LMFAO so true
:blush:
02 Stratus
Edited by Ronin
What kind of amp is it?
Depending on if it uses vertical, horazontal, or 45degree mosfet mounting can determine if the amp will work ok on a box or not. Vertical fets are the worse and to many vibrations may cause the mosfet legs to snap and fry the amp.
The way Rockford Amps are made and how the mosfets are mounted is what allows people to mount them on the box.
I personally dont see a sheet of sound deadening of ANY KIND will eliminate the vibrations caused from mounting a amp on a box.
The only proper way to do it is with 4 soft rubber type spacer/washer (at least 1/4 to 1/2 inch long to put between the amp and the box, and NOT tighten the mounting screws totally tight to the point you compress the rubber bushings fully.
Edited by Audiofanaticz
Zapco amp,I'm not mounting on the box. Too many issues with that,if someone gets into my car that will be too easy to just snatch the box and have damn near everything.
Edited by Ronin
Best way to Mount an Large amp is to get one of these.
Really try bolting the box to the floor then Bolt the amp to the box with some rubber grommets.
