Murda_Mitten Posted April 5, 2010 Report Posted April 5, 2010 I just read something in a Zapco article where they claim 1ohm sounds muddy and 4ohms sounds better. I also hear that a/b sub amps have much better control of the woofer resulting in a better response. Does anyone agree with this?
AI James Posted April 5, 2010 Report Posted April 5, 2010 It's pretty much true... Class ab for me. Better slew and damp factor
loganberry Posted April 5, 2010 Report Posted April 5, 2010 thats why stuff like zapco/audison/hertz/focal is soo expensive because they are better, sound better, more adjustability..just a all around better amp My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
Afrodeezyak Posted April 5, 2010 Report Posted April 5, 2010 from what ive heard the higher the impedance the better the sound quality but you sacrifice power in this instance I also believe that a/b amps have a better response and better quality cause they seem to focus on powering mids and highs where as class d's are purely power to feed the subs
loganberry Posted April 5, 2010 Report Posted April 5, 2010 from what ive heard the higher the impedance the better the sound quality but you sacrifice power in this instance I also believe that a/b amps have a better response and better quality cause they seem to focus on powering mids and highs where as class d's are purely power to feed the subs jbl's big amp does 8k at 4 ohm My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
devil4u2c Posted April 5, 2010 Report Posted April 5, 2010 yeah I used to know a rich kid that had a couple of zapco amps, he was replacing a couple of orion amps, and his system did sound quite a bit better, for the record he was running focal all around. I deffinately like me some zapco amps
Afrodeezyak Posted April 5, 2010 Report Posted April 5, 2010 jbl's big amp does 8k at 4 ohm touche haha... but damn thats a lot of power
dwright27 Posted April 5, 2010 Report Posted April 5, 2010 jbl's big amp does 8k at 4 ohm if you ask chode they are piece of shits. 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
loganberry Posted April 5, 2010 Report Posted April 5, 2010 if you ask chode they are piece of shits. then thats one piece of shit i wouldnt mind having My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
TeamHT Posted April 5, 2010 Report Posted April 5, 2010 i believe the best way to answer your question is to explain the differences in the types of amplifiers. class a, class b, class AB, class d the most common. class a is more common with smaller linear amps, where efficiency is not its aim ie:the amount of inputted signal that is actually converted and used. class b amps usually have 2 output devices which conduct alternatively (push and pull) exactly for 180* or half cycle, using half of the inputted signal. class AB utilizes the 2 active elements more than half of the time in order to help reduce cross over distortions. class d was meant for the most efficiency meaning as much as possible of the inputted signal is converted and used ie more power. Tell me...does this smell like chloroform to you?
