hey everybody can you put aftermarket tint of the factory window tint that come on my car or do i need to remove the factory tint first??
ive heard of people putting tint over the factory tint but i dont know if its the right way.if your try to put the same tint all the way around i would take off the factory tint first and then put the new tint on.
you can but it will make it darker. most factory tint is around 20% so if you do 20 over that it will make them around 10% but it depends on the vehicle and darkness of the tint. to answer your question yes tyou can. but it will be much darker
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
actually most cars come with around 75% tint.
and yes you can tint over the stock tint. just remember that your tint is going to meter darker than the aftermarket tint that you get, because the stock tint and the aftermarket tint are both on the window.
i did this and my 5% tint meters 2.5%.
Edited by jesseanson
2004 gmc Yukon
270 amp mechman alt.
1 odyssey PC1500 up front
6 kinetik HC2400's in the back
2 18" BTL's fully loaded
2 saz-3500d's strapped
155.7db @ 38hz sealed :)
MY YOUTUBE!!!
  • 3 months later...
factory tint is inside the window, they heat up the glass and shoot a dye inside it with a needle. i always thought it was outside the window until i started working at a tint shop. ANY tint you can peel off is aftermarket, you can put it over the aftermarket tint if you wanted tho.
I SCAM PEOPLE OUT OF MONEY... AVOID ME LIKE I AM AN AIDS INFECTED RETARD...
well every car comes with factory tint. if you have an suv however and you add to the back window tint itll make it look ALOT darker than you may want. you should do it over the factory tint though cause from what ive heard its alot easier to do if the tint is suv dark
Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward
The Revolution Was Not Televised
But There Is This Thread(clicky)
Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc
Listen to this. Factory tint is not a film you peel off. The glass itself is tinted. It's just glass and tint goes right on but it will be darker with the tint and factory glass.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
  • Who's Online   0 Members, 0 Anonymous, 3030 Guests (See full list)
