Does anyone know what would cause a amp to corrode
Blake629
moisture. wet feet on the floor. try relocating the amp someplace dry or make a lil "amprack" under the seat to lift it off the carpeting
Moisture getting in your car from the snow on your shoes, general moisture in the air, maybe your ass sweats a ton...lol jk on the last one.
EDIT 500th POST!!!!!!!!!!!!!
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
I have a amp that's mounted under my seat it started corroding at the screws then spread to bottom of the amp and I don't know what's cauing it. Could anyone give me some suggestions
could be dissimilar or bimetal corrosion. if you used cheap hardware or if the seat is steel and the amp is aluminum (likely) and you try to clamp them together, they will corrode. I'm in aviation and this is probably the biggest problem we have with corrosion
Kenwood DDX 514
DD M3a
DD 9512G
RF 600.4
RF power series 6x8s
lots of zero ga.
Whats coming: Kenwood Excelon screen, DD high end comps, DD 4ch, XS batteries
the amp is aluminum so that should be the problem thanks
Thats a negative its proply water or something thats leasking in there
aluminum shouldnet be that corroded
This might be a long shot, but I have seen instances, not necessarily with car audio, but with 12v battery electronics, where corroding can occur like electroplating. If you amps ground is thru the chassis, and you amp is secured with screws to the chassis, then there could be some corroding or electroplating of some sorts going on at the contact point. I forgot the exact term that this is for, but when I was in college we did a lab that dealt with double grounds, and it can cause corroding.
take baby steps, u cant do it all at once unless u have a roll of 100's big enough to choke a donkey
1998 Chevy Venture "Swagger Wagon"
Kenwood Excelon KDC-X994 Headunit
3 15" Alpine Type R's in seperate T-Lines
1 RF T1500-1bd for 2 of the 15s
1 RF P1000-1bd for the single 15
3 sets of Hifonics Zeus ZXi6.5C Components( 1 more set to come for Front stage)
1 Hifonics HFi100.4 4-channel amp
Stock alt for now (DC HO SPL 400A when funds come in,currently working on buying this)
Stock battery and one Optima Redtop for now (looking at XS batteries)
3 15" Alpine Type R's (aka Swagger Wagon Build 1.0)
Swagger Wagon Build 2.0
Youtube Videos
  • Who's Online   0 Members, 0 Anonymous, 1789 Guests (See full list)
