sounds about right
R.I.P!
(Nov-29-2009)
92 explorer
current build
What vehicle? Seems about right if
in a trunk i only did a 143.9
My guess is you were clipping to shit :)
Edited by BeAlLsTaR13
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
what kinda car/truck? hows your electrical? how big of a box? whats it tuned to? alot of things can affect your score.
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
sounds low to me. BUT it could easily be your song choice. or if they are in the trunk it would be right. find what frequency you peak at then find a song that plays that frequency.
give more system details, box size, tuning, electrical, ohm load, song played, trunk car or in the cab, ports and subs firing direction, etc.
Yea you need to factor in these things:
vehicle it's self, trunk, suv, truck ect
frequency - where does your vehicle peak at?
Air movement - can the air in the vehicle move freely, no obsticles such as seats boxes amp racks ect. The air needs to be able to move freely into the cabin
cabin temperature - I've noticed that the coler the cabin temp is, higher the score
electrical - better hope your not running 2k on stock electrical, 1/0, big 3, alt, batts ect can factor you could be getting low input voltage
and TONS more can factor in
Team Sundown Audio
Box tuned to 37 hz, I think 2 cubes per sub, 2 ohm, song bme click, in trunk subs firing toward front, 240 amp alternator, duralast gold in front and kinetik 2400 in back, 0 guage, big 3, its a sedan btw too.
I am going to guess and assume your box is NOT sealed off from the trunk
when you have subs firing in you néeD to seal it off from the trunk
Turn your box aroud, it'll go up. I witnissed this last week a guy at a show had an SSA sub do mid 130 firing in not sealed off from the trunk I told him to turn it around since it's not sealed from the trunk, he hit a 14x.x after he did
Team Sundown Audio
each sub is wired to 2ohm or they are 2ohm coils? turn the box to face the rear. you "think" 2 cubes? did you build it or is this a prefab box? what size is the port? how did you tune the amps? are the subs sharing the same airspace?
