Alright so I plan on buying a 15" Fi BL and I have the option of dual 1 ohm or dual 2 ohm
and I'm not sure which one to pick, like if I were to pick a dual 1 ohm setup, what type of
amp would I run with that? Same with the dual 2 ohm. Sorry for being complete noob
but I'm still learning stuff and if anyone could give me a brief explanation I'd appreciate it.
Oh and I guess I might as well ask what type of amp would you guys recommend, I'm looking to run
it at about 1000-1200watts since I'm running stock electrical. Thanks for your time!
i would upgrde your electrical either way but i would run the duel 2 if your only doing one sub that way you can wire your amp down to 1 ohm and get a good mono block amp that puts out around 1000 watts at 1 ohm like audioque 1200 or sundown 1500 or a rockford t1k or something like that
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
the dual 1 is actually going to run a load of 0.7ohms if wired with 1 amp and the dual 2 is going to be 1.4ohms if im not mistakin
Wrong, dual 1 can be wired to 1.4 or 0.35 ohm.(aka 2 or 0.5ohm)
Dual 2 can be wired to 2.8 ohms or 0.7 ohms.(aka 4ohm and 1ohm)
Sundown >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> lots of things >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> alpine...
Hammerdown... 1%
I have the aq2200 and I love it, I would go with the aq1200 for your application
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
  • Who's Online   0 Members, 0 Anonymous, 748 Guests (See full list)
