Ricky A. Posted May 2, 2010 Report Posted May 2, 2010 ok yall i made a wierd shaped box to fit my truck for an fi btl 15 and heres how i tuned it. its 32 hertz 6.6 cubes gross volume port area (area of each side added together) 430 inches squared port volume is 630 inches squared or .9 cubes. 3.5x10x18 inches deep port tube ends only 1.5 inches fromt he back wall. sub displacement is .22 cubes soo net volume is 6 cubes. DOES THAT SOUND WRONG OR IS THE PORT TO SMALL? pic BUILD LINK: http://www.stevemeadedesigns.com/board/topic/112034-2-sundown-18s-98-f-150/page__p__1565972__fromsearch__1#entry156597298 Ford F-150Truck:37" superswamper tsl radials16" ion alloy wheels3" body lift2" suspension liftOffbrand brushguardPIAA driving lights6000K HID'sSystem:2 18" Sundown NightshaedAq3500Custom Fiberglass boxfosgate T1 6x8 Coxialsbass inferno 2000 watt 4 channel2 XS power d3100's0 Gauge
zayres29 Posted May 2, 2010 Report Posted May 2, 2010 port area is the width and the height of the port not the area of each side added together the port looks too small Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
kirill007 Posted May 2, 2010 Report Posted May 2, 2010 Port IS too small, 35sq inches for 6.6 cu ft is no where near enough. Optimal would be 85sq inches.(but you would need to make the port longer so you don't mess up the tuning.) Thinking is the root of all problems... You ALWAYS get what you pay for.
Ricky A. Posted May 2, 2010 Author Report Posted May 2, 2010 Port IS too small, 35sq inches for 6.6 cu ft is no where near enough. Optimal would be 85sq inches.(but you would need to make the port longer so you don't mess up the tuning.) if you increase the opening of the port shouldnt the port depth be shorter not longer to keep the same tuning?? BUILD LINK: http://www.stevemeadedesigns.com/board/topic/112034-2-sundown-18s-98-f-150/page__p__1565972__fromsearch__1#entry156597298 Ford F-150Truck:37" superswamper tsl radials16" ion alloy wheels3" body lift2" suspension liftOffbrand brushguardPIAA driving lights6000K HID'sSystem:2 18" Sundown NightshaedAq3500Custom Fiberglass boxfosgate T1 6x8 Coxialsbass inferno 2000 watt 4 channel2 XS power d3100's0 Gauge
J-Lane Posted May 2, 2010 Report Posted May 2, 2010 if you increase the opening of the port shouldnt the port depth be shorter not longer to keep the same tuning?? No, as the area of the port becomes larger the length will increase as well... From Fi's web site... "BTL 15 – Ported box we recommend using 3-5 cubic feet @ 30-35Hz. Again use 12-16 square inches of vent area per cubic foot of volume. " So 6.6 cu. ft. x 12 sq. in. = 79.2 sq. in. of port area. So if your port is say 3.5 in. wide / 79.2 sq in = 22.62 in. tall and if you have an internal box size of 6.6 cu. ft. and you want to tune it to 35 hz the port length would need to be 20.49 inches in length. I'm not sure if you said 6.6 cu.ft. internal but this is just an example. Remember to also take into account the displacement of the port as well as the speaker when calculating the box volume. The smallest mistakes will greatly affect the tuning of your box. Btw if your internal volume is 6.6 cu.ft. you may want to decrease that to 5 cu. ft. as well because a box that is too large will affect performance as well and that is larger than the manufactures recommended enclosure size.
Ricky A. Posted May 3, 2010 Author Report Posted May 3, 2010 ohhhh ok thank you very much i also messed up my math a bit ill redo it all tonight and post what i come up with tomorrow. and if the length is to much just 90 degree andgle the port and continue it right? BUILD LINK: http://www.stevemeadedesigns.com/board/topic/112034-2-sundown-18s-98-f-150/page__p__1565972__fromsearch__1#entry156597298 Ford F-150Truck:37" superswamper tsl radials16" ion alloy wheels3" body lift2" suspension liftOffbrand brushguardPIAA driving lights6000K HID'sSystem:2 18" Sundown NightshaedAq3500Custom Fiberglass boxfosgate T1 6x8 Coxialsbass inferno 2000 watt 4 channel2 XS power d3100's0 Gauge
Ricky A. Posted May 3, 2010 Author Report Posted May 3, 2010 OKAY haha i re-did all my math and got 4.5 cubes. and im tuning to 32 hertz. so the port area i need is 63 inches squared (14 PER CUBE) and that gives me a size of 4.5 inches tall 14 inches wide and 23.25 inches deep. and after port displacement which is .8 cubes and sub displacemt. .2 cubes ill have 3.5 cubes net volume. which is in the subs reccomended size. so i should be good! right? port sketch. (rough i know) BUILD LINK: http://www.stevemeadedesigns.com/board/topic/112034-2-sundown-18s-98-f-150/page__p__1565972__fromsearch__1#entry156597298 Ford F-150Truck:37" superswamper tsl radials16" ion alloy wheels3" body lift2" suspension liftOffbrand brushguardPIAA driving lights6000K HID'sSystem:2 18" Sundown NightshaedAq3500Custom Fiberglass boxfosgate T1 6x8 Coxialsbass inferno 2000 watt 4 channel2 XS power d3100's0 Gauge
Alex K Posted May 4, 2010 Report Posted May 4, 2010 damn lol you like oldstyle dont you? Pen and paper and the trusty mental math..lol. Why not download sketchup, get torres calc, and go nuts? 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
