07 TBSS Fi Team 18's B-Walled 4th
Shoulda went with DC power. :peepwall:
2004 Yellow F150 STX 4x4 Single Cab
2 Yellow DC Power 270SP's Alts
4(and counting) XS Power 6500's
4 DD3515s Supercharged
53cu.ft 4th order blowthrough
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
154.1 @ 41hz Legal Burp
Build Log
Anything but Iraggi would have been fine I guess. Then again if I went with DC I would still be waiting for my alternators... ;)
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
Yea, but think of all the time saved of not having to send em back every month.
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
Build Log
I took it so I'm posting it, but the video blows, as I said when I started the next one I thought I smelled coil but quickly realized it wasn't coil, more like sweet burning plastic, then I saw smoke from the hood... See the voltage, I was suspicious when I saw it hit 12.1 as it wasn't going balls out and I had just started playing it... Well shortly there after I think the regulator blew up.
Going to head out to Xtreme to get on Tom's TL tomorrow and see what it puts up, I'll try to remember my camera :D I should kill that 140.6 at 28hz now :clapping:
About to be three returns... :angry:
Pioneer X8500
Second Skin
2 270a Mechman Alts
Looks. Real good but do u have any pics of the wire under the truck? If you are on tbss owners it explains the whole ground issue in depth, I still haven't dealt with the headliner removal because of the dvd player and bullcrap.
Be very carefull with those Knu fuse holders with the 3 miniAnls - they do not like bass or vibrations...at least they never worked for me - I kept having them come loose and causing voltage issues. I stick with Stinger ANL holders that accept soldered 0-rings
The SS looks great though! sweet truck.
hope you get your problems solved
2003 Dodge Ram 1500 - Deep Orange
Build log - Blowthrought with 4 18's http://www.stevemeadedesigns.com/board/topic/122600-4-18s-in-a-dodge-ram-team-sundown-russia/
Sundown Audio SAX125.2 - Sundown PA 10"
Shok-wiring & RCA's
XS Power D6500
Mechman 320A
Sundown Audio Russia
http://sundownaudio....dex.php?/index
http://www.drive2.ru...ram/ram/skillz/ - more about my truck
http://www.youtube.com/user/Gskillz81
Thanks man, I haven't had a problem with them yet (not to say I won't). Two of them have been sitting in that location since early May and have held up OK. I will be sure to keep an eye on them though. I actually have lug holders in the rear of the truck because they are not only cheaper, but I just trust a ring more than some compression fitting. If the DATs don't go back in I have enough of them to swap out the KNU's should the need arise (2 not being used in the rear and 3 backups). Those KNU's would work better in the rear anyways (front to rear run).
Which reminds me, we did kind of forget to fuse the back, I gotta get that done in the next few days before I forget <_<
Pioneer X8500
Second Skin
2 270a Mechman Alts
Well per usual I forgot to actually use my camera... Anyways, I did a 156 for a split second but the jackass forgot to set it to peak hold... <_< Not sure if that number was real or not (I vote not, but the guys swore up and down it did it), but after that (once my voltage tanked in the 12's) the best I could do is a 148.8 which ain't too bad on 12v (stock 145a alt) ;) I also forgot which song it was that I went over 150 on... fail
For the record it was sealed on the dash, can't wait to try again with my alts and again I'm just happy it's playin :D This box needs a redo mainly because it's tuned so damn low with where it sits. I think I was peaking at 28hz down in Columbus and playing stuff that low makes me a little nervous. :pardon:
On a side note if Dom doesn't refund me on this 300a it will be up for sale when it gets back from repair.
Sorry man just noticed your response. The ground issue is only partially fixed. There is a ground strap near the battery which is the factory inductive pickup which needs to be incorperated in order to get the ECU to respond to the additional load. I think what I need to do is make alt ground one 3/0 run which I might be able to fit in that pickup. :pardon:
Right now under full load the most the alt puts out (unless I trick it) is 13.8v. If I start the truck and load it right away it stays in the 14's and 15's for a couple minutes. Unfortunately that is just how these 2 plugs charge, low and slow like my smoker :P
I wish they made a VCM for my truck :( 2 plug 2 wire FTFL... Going to check on an MLA, that would resolve the issue.
Pioneer X8500
Second Skin
2 270a Mechman Alts
I would suggest you seriously look into an MLA...can you say voltage FTMFW! I love mine and would live with out it! Great build bro.
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
