07 TBSS Fi Team 18's B-Walled 4th
You should lend a canadian some 4500s... Hahaha
Trust me, with my luck you don't want to be the first one to hook up these amps... :P
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
:jon: lets just hope you dont have too much motor force
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
:ninja:
Should be good, I'm not zip tieing the amps to the motors like some people... :P
Pioneer X8500
Second Skin
2 270a Mechman Alts
  • 1 month later...
Well it's been awhile and as per usual FML
Got my rebadging goodies and obviously there were issues, the billit rear emblem is wrong or bent and doesn't fit, but no biggie
Getting darker ;) I was rearended awhile back so when it goes in for those repairs I'll have the front chrome fake brake cooling vents blacked out as well. I also adjusted the rear height a tad, but with all the weight I don't want to go much lower or I'll have to trim the bump stops.
Next up we have the new (I use that term loosely) amps, 2 SAZ-4500s (a21bravo beat these up a bit, but they work and just require a little TLC so no harm, got a good deal so it should be expected)
WTF?
Andy did some recone love on the one LVL5 that had the motor falling off (the bolts just came loose) and put it back in along with one of the 4500s
Then on to getting the pillars in, but after I heard them, I definately have to wind up redoing them (not now) as they are aimed too far forward and didn't lay down quite how I thought they were going to once they were wired up.
The other 5's coil let loose... That's my 2nd seemingly perfect coil (to the eye) on 2 different amps that let go in the same place, so whatever.
Then something... something... something... happened...
It's all out... Need to build a new amp rack for the 4500s and batts... what batts? These batts :D
That'll get me up to 6 3400s ;)
...and a charger
Then something else happened...
Shipped/Billed On:05/16/2013
Type:Package
Weight:89.30 lbs
Type:Package
Weight:89.30 lbs
Wonder what those could be? Hmmm?
Pioneer X8500
Second Skin
2 270a Mechman Alts
Good build man. I dig the new subs your getting! Little birdie told me ..lol
Me too! Just hope I have better luck with them, the wall is around 13.x cubes so they should be way happier than the 5's were :D I think my tuning is a little high for them (35/36), but we'll see how it goes.
Andy is getting the steel cage together this week for the batts and then the amp rack is going to grow off of that. There isn't nearly enough space back there, but that's what I get for walling it to the max. As it turns out there is only like .25" between the bus bars and the center of the tailgate which juts out so it's soooo close... lol
We tried doing it in birch/mdf, but the gap over my cubby in the back is too wide to hold up the weight of 5 or 6 batts so had to go steel. Getting super stoked.
Pioneer X8500
Second Skin
2 270a Mechman Alts
Love the look of your ride .. I think your goin to be a happy camper real soon .. Can't wait to see a vid
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
WEAKSAUCE... Just sayin...
How ya been man? You ever get that thing metered? How do you like the DC's?
