Ndnkobra Posted May 9, 2010 Report Posted May 9, 2010 Hey guys, i was just looking under the hood and I noticed that my battery terminals, along with the bolts on it have completely rusted. I dont want to remove any bolts in fear of stripping them because of the rust, so do you guys have any suggestions of removing the rust without harming the battery? I need to get the rust off the terminals and the bolts. Thanks!
BeachJoshua Posted May 9, 2010 Report Posted May 9, 2010 Hey guys, i was just looking under the hood and I noticed that my battery terminals, along with the bolts on it have completely rusted. I dont want to remove any bolts in fear of stripping them because of the rust, so do you guys have any suggestions of removing the rust without harming the battery? I need to get the rust off the terminals and the bolts. Thanks! If you had an optima you'd take it back to them and get a free one. | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
Ndnkobra Posted May 9, 2010 Author Report Posted May 9, 2010 It's not an optima, its a stock for now. and i should probably clarify on the battery. The posts themselves arent rusted but the connectors are.
Ji553r Posted May 9, 2010 Report Posted May 9, 2010 i have that problem a tiny bit i am just going to get a new battery im doing the big 3 anyway i am not going to worry about the stock wires unless it appears to cause real harm I don't fuck around. I go from zero to I hope you die in less than 2 posts build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
EricM9104 Posted May 10, 2010 Report Posted May 10, 2010 Replace em. Trust me, remoing the rust won't fix it. Terminals will still snap in half upon removal. 2015 Honda Civic LX 4dr | 110k miles | Stock 1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
baaudio Posted May 10, 2010 Report Posted May 10, 2010 wire brush and elbow grease. then remove and clean batt posts and redo replace terminals Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
Skullz Posted May 10, 2010 Report Posted May 10, 2010 Mix some baking soda in some warm water and pour it over the post to remove any caking deposits and just clean the rust off the terminals. Take a piece of copper and glue it right between the battery post under the hood to prevent any more deposits building up on the ground terminal. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
