I currently have a Fi BTL 12" at 2 ohms and I had a power acostik 5500bamf amp that died yesterday.everytime id turn it up or hit a bump my bass would cut out.and the amp protection light would come on.so i opened it after checking all my connections and noticed one of the capacitors vibrated loose.SO i was looking into amps and i saw the Rockford Fosgate T2500-1bd. does anybody know if id be able to run this ?
You can, you can wire that sub up to either 1 or 4 ohms, and the amp is stable in both cases. I think you'd be safe as long as you dont abuse the gains on the amp, also hopefully your electrical is up to par for that amp, it produces raw power.
but what do u mean? my sub is a 2 ohm. the stats say that the amp is 2500 rms while my btl is 2000rms.im confused about what u said with 1 and 4 ohm
If your btl is a dual 1 ohm, you should look for an amp that puts its power at 2 ohms.
This RF amp is not the best choice for a DVC1 sub.
Take a look at :
Audiopipe 3000.1
2 Sundown saz 1000 or 1500 strapped
Kicker 2500
Alpine mrp something 2000
And many more !
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
Take a look at :
Audiopipe 3000.1
Kicker 2500
And many more !
my sub is a 2 ohm
It's called impedance, both your amp and sub have an impedance. Its basically resistance with AC (someone will have to clarify me on that), i'm not too informative about it, but the lower your resistance the more current will flow, thus the more power you will recieve. Your coils in your sub also have an impedance, which you can then decide how to wire it, either in series, parallel, or series/parallel. I'd look at a wiring diagram for that, but basically at 1 ohm for that rockford amp it does produce 2500 watts of power, and your average power handling on your sub is 2000 watts. Now unless you're really smart about putting extra power into your speaker, you shouldn't do it. You would be pushing your speaker above the given RMS, not by much, but the rating acts as a guideline on how much power you should use. Now, thats at perfect conditions, you can set your gains on your amp to limit the amount of current flowing through into your amp, there's a power chart somewhere and with a use of a multimeter you can set your ACV to match the amount of power you want, 2000 watts. You can set it lower than that too, only if your electrical isnt up to handling over 2k watts of power. In shorter terms, that amp produces 2500 watts at 1 ohm, and 1000 watts at 4 ohms. If you notice that your battery commits suicide or your headlights dim, you need to either set the gains down or if you know for sure that your electrical cant handle that much power, wire it to 4 ohms.
Edited by Ndnkobra
my sub is a 2 ohm
dual 2 or dual 1 (wired up to 2 ohms)? What options are on the amp (cooling, heat ring, etc)?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
DVC 2 ohm
1000 Watts RMS x 1 @ 4-Ohms
1800 Watts RMS x 1 @ 2-Ohms
2500 Watts RMS x 1 @ 1-Ohm
Two amplifiers in bdSYNC configuration: 5000 Watts RMS x 1 @ 2-Ohms
General Features
0°/180° Phase Switch
1/0 AWG power/ground connectors
24dB/octave crossover
Audiophile grade speaker connections
Infrasonic filter
LED Signal/Power Meters - monitors signal & voltage with simulated VU needle
MasterSync - allows 1 amplifier to control an array of amplifiers
MOSFET output stage
MOSFET power supply
PowerSync - allows 2 amplifiers to be "strapped" together
RCA pass-thru
General Specifications
Efficiency (average): 87% @ 4-Ohm, 86% @ 2-Ohm, 75% @ 1-Ohm
Crossover Controls: Low-Pass (LP): 35Hz-250Hz @ 24dB/octave Butterworth
Infrasonic: 12dB/octave Butterworth, -3dB @ 28Hz
Tone Controls: Bass: 0dB to +18dB @ 45Hz
Signal Input: 1 RCA pair
Signal Output: 1 RCA pair
Power Input Connector: Block
Power Wire Gauge: 1/0 AWG
Speaker Output Connector: Block
Speaker Wire Gauge: 8 AWG to 16 AWG
Heat Sink Type: Cast aluminum
Cooling: Convection
Remote Controls: Optional Remote PEQ
(overrides built-in Punch Bass)
Visual Indicators: Power (Blue LED)
Thermal (Red LED)
Protect (Yellow LED)
Output -00dB to +2dB @ 11 steps (Blue LEDs)
Battery 9VDC to 16VDC @ 11 steps (Blue LEDs)
bd Circuit Topology Class
Frequency Response: 20Hz to 250Hz +/-0.5dB
Dimensions: 2.14 x 8.14 x 21.875 (in)
welcome aboard dude. If you need a hand with anything let me know. You got my number still(its nate. Ran into you at Ray and charles deli a while back) My truck is in the shop again so I got some free time
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
OMG LMAO,its soo weird u found me on here haha.yea i still got ur number.my amp vibrated apart.im about to order this rockford amp but its 500 watts above the rms for my sub.i was told i could set my gain down but i wanna make sure before i spend over a grand.i gotta hear ur truck sometime
  • Who's Online   0 Members, 0 Anonymous, 2852 Guests (See full list)
