Gees97 Posted May 9, 2010 Report Posted May 9, 2010 I currently have a Fi BTL 12" at 2 ohms and I had a power acostik 5500bamf amp that died yesterday.everytime id turn it up or hit a bump my bass would cut out.and the amp protection light would come on.so i opened it after checking all my connections and noticed one of the capacitors vibrated loose.SO i was looking into amps and i saw the Rockford Fosgate T2500-1bd. does anybody know if id be able to run this ? Quote
Ndnkobra Posted May 9, 2010 Report Posted May 9, 2010 I currently have a Fi BTL 12" at 2 ohms and I had a power acostik 5500bamf amp that died yesterday.everytime id turn it up or hit a bump my bass would cut out.and the amp protection light would come on.so i opened it after checking all my connections and noticed one of the capacitors vibrated loose.SO i was looking into amps and i saw the Rockford Fosgate T2500-1bd. does anybody know if id be able to run this ? You can, you can wire that sub up to either 1 or 4 ohms, and the amp is stable in both cases. I think you'd be safe as long as you dont abuse the gains on the amp, also hopefully your electrical is up to par for that amp, it produces raw power. Quote
Gees97 Posted May 9, 2010 Author Report Posted May 9, 2010 You can, you can wire that sub up to either 1 or 4 ohms, and the amp is stable in both cases. I think you'd be safe as long as you dont abuse the gains on the amp, also hopefully your electrical is up to par for that amp, it produces raw power. but what do u mean? my sub is a 2 ohm. the stats say that the amp is 2500 rms while my btl is 2000rms.im confused about what u said with 1 and 4 ohm Quote
notorious97200 Posted May 9, 2010 Report Posted May 9, 2010 If your btl is a dual 1 ohm, you should look for an amp that puts its power at 2 ohms. This RF amp is not the best choice for a DVC1 sub. Take a look at : Audiopipe 3000.1 2 Sundown saz 1000 or 1500 strapped Kicker 2500 Alpine mrp something 2000 And many more ! Quote black BMW X1 2.0 l 192 hp OEM head unit, Amplifiers : Audison AP 8.9 with integrated DSP and Ampere Audio 1200. Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats. 2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
Gees97 Posted May 9, 2010 Author Report Posted May 9, 2010 If your btl is a dual 1 ohm, you should look for an amp that puts its power at 2 ohms. This RF amp is not the best choice for a DVC1 sub. Take a look at : Audiopipe 3000.1 2 Sundown saz 1000 or 1500 strapped Kicker 2500 Alpine mrp something 2000 And many more ! my sub is a 2 ohm Quote
Ndnkobra Posted May 9, 2010 Report Posted May 9, 2010 (edited) It's called impedance, both your amp and sub have an impedance. Its basically resistance with AC (someone will have to clarify me on that), i'm not too informative about it, but the lower your resistance the more current will flow, thus the more power you will recieve. Your coils in your sub also have an impedance, which you can then decide how to wire it, either in series, parallel, or series/parallel. I'd look at a wiring diagram for that, but basically at 1 ohm for that rockford amp it does produce 2500 watts of power, and your average power handling on your sub is 2000 watts. Now unless you're really smart about putting extra power into your speaker, you shouldn't do it. You would be pushing your speaker above the given RMS, not by much, but the rating acts as a guideline on how much power you should use. Now, thats at perfect conditions, you can set your gains on your amp to limit the amount of current flowing through into your amp, there's a power chart somewhere and with a use of a multimeter you can set your ACV to match the amount of power you want, 2000 watts. You can set it lower than that too, only if your electrical isnt up to handling over 2k watts of power. In shorter terms, that amp produces 2500 watts at 1 ohm, and 1000 watts at 4 ohms. If you notice that your battery commits suicide or your headlights dim, you need to either set the gains down or if you know for sure that your electrical cant handle that much power, wire it to 4 ohms. Edited May 9, 2010 by Ndnkobra Quote
hdorre Posted May 9, 2010 Report Posted May 9, 2010 my sub is a 2 ohm dual 2 or dual 1 (wired up to 2 ohms)? What options are on the amp (cooling, heat ring, etc)? Quote On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Gees97 Posted May 9, 2010 Author Report Posted May 9, 2010 dual 2 or dual 1 (wired up to 2 ohms)? What options are on the amp (cooling, heat ring, etc)? DVC 2 ohm 1000 Watts RMS x 1 @ 4-Ohms 1800 Watts RMS x 1 @ 2-Ohms 2500 Watts RMS x 1 @ 1-Ohm Two amplifiers in bdSYNC configuration: 5000 Watts RMS x 1 @ 2-Ohms General Features 0°/180° Phase Switch 1/0 AWG power/ground connectors 24dB/octave crossover Audiophile grade speaker connections Infrasonic filter LED Signal/Power Meters - monitors signal & voltage with simulated VU needle MasterSync - allows 1 amplifier to control an array of amplifiers MOSFET output stage MOSFET power supply PowerSync - allows 2 amplifiers to be "strapped" together RCA pass-thru General Specifications Efficiency (average): 87% @ 4-Ohm, 86% @ 2-Ohm, 75% @ 1-Ohm Crossover Controls: Low-Pass (LP): 35Hz-250Hz @ 24dB/octave Butterworth Infrasonic: 12dB/octave Butterworth, -3dB @ 28Hz Tone Controls: Bass: 0dB to +18dB @ 45Hz Signal Input: 1 RCA pair Signal Output: 1 RCA pair Power Input Connector: Block Power Wire Gauge: 1/0 AWG Speaker Output Connector: Block Speaker Wire Gauge: 8 AWG to 16 AWG Heat Sink Type: Cast aluminum Cooling: Convection Remote Controls: Optional Remote PEQ (overrides built-in Punch Bass) Visual Indicators: Power (Blue LED) Thermal (Red LED) Protect (Yellow LED) Output -00dB to +2dB @ 11 steps (Blue LEDs) Battery 9VDC to 16VDC @ 11 steps (Blue LEDs) bd Circuit Topology Class Frequency Response: 20Hz to 250Hz +/-0.5dB Dimensions: 2.14 x 8.14 x 21.875 (in) Quote
n8ball2013 Posted May 9, 2010 Report Posted May 9, 2010 welcome aboard dude. If you need a hand with anything let me know. You got my number still(its nate. Ran into you at Ray and charles deli a while back) My truck is in the shop again so I got some free time Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Gees97 Posted May 9, 2010 Author Report Posted May 9, 2010 welcome aboard dude. If you need a hand with anything let me know. You got my number still(its nate. Ran into you at Ray and charles deli a while back) My truck is in the shop again so I got some free time OMG LMAO,its soo weird u found me on here haha.yea i still got ur number.my amp vibrated apart.im about to order this rockford amp but its 500 watts above the rms for my sub.i was told i could set my gain down but i wanna make sure before i spend over a grand.i gotta hear ur truck sometime Quote
