Theoretically speaking... could this work?
Hey everyone, let me first say that ive been checking out the threads on this forum and ive learned so much already so ive decided to join :D
i could see how it may not work if people do it already; but would it be beneficial in a multiple subwoofer setup to tune two ports at different frequencies to cover a broader range?
1995 Buick Lesabre, Jbl GTO5355 =1.5 farad cap running a JBL gt4 12" and 4 infinity reference 6x9s
Theoretically a subwoofer is like a play ground. As long as you pay attention to mechanical damage you can try just about anything you can think of with a subwoofer.
If you start messing around with Extreme SPL vehicles you will see alot of wild ideas.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
I may be wrong but I think that may cover a broader range but could cause cancellation? I'm curios now myself, LOL
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
i tried this. i made 2 different boxes. looked like one but had wall in between both. one was tuned to 30hz and the other 34hz. i couldnt really tell a diff.
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
if you did that you would need to band pass the hz so they didn't overlap to much and integrate with each other smoothly. like 50\/ tuned to 30hz and 50-125hz or so tuned to 60ish or round about that sorta. You'd probably need 20-30hz ish between tuning. BUT that's just my 2cents. Id say putting them to close would be infective for the broad range and not bandpassing it would cause cancellation
JVC AVX-44 and 360.2
Subs: 2 RF T1 12s 1ohm mono off a RF T1500bdcp 80hz \/ in a 2.3cube 45hz slot port
Mids: 2 O2 8's off a Punch 550.2 behind seat, 2 Image Cxs 6.5's and 2 ID XS 6x9s 80-3khz in doors on a T600.2
Highs: 2 ID CD.1 MH HLCD 8ohm off a RF 400.4 3khz /\
I'm tempted to say you could do this with a single port as well.. with a bit of math and trial and error and a hacksaw and some baffles....
Hammerdown... 1%
so basically the ideal way to do it is in an Aperiodic Bi-Chamber, creating octaves and therefore basically increasing volume output through harmonies... too bad it takes up so much more space haha
id imagine if you mess up a dimension youd get some distortion/cancellation with the second chamber out of tune with the first, but hey, its worth a shot to play around
well thanks guys :D answered my question perfectly
  • Who's Online   0 Members, 0 Anonymous, 1949 Guests (See full list)
