troy Posted May 19, 2010 Report Posted May 19, 2010 I just hooked up my HDC3 today on about 500 rms just to play with it a lil bit. But i hear this annoying ass rattle that sounds like its coming from the cone. The same kinda noise that you hear if you sat a screw on the cone and let it bounce and rattle around. is there any ideas of what it could be??? retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
baaudio Posted May 19, 2010 Report Posted May 19, 2010 is a tinsel slappin the cone? Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
spl4life Posted May 19, 2010 Report Posted May 19, 2010 loose dustcap??? highly doubt it... possible tear on the surround? does it sound like metal on metal? My first truck... My first Real build... *Update 8/9/10 DC Power 270xp Alt is In!!!* 1997 Toyota T-100 DC Level 5 18" in a T-line Everybody wants their system to be.... 1. Cheap 2. Reliable 3. Loud ...you can only pick two. micahmye hertz pack
troy Posted May 19, 2010 Author Report Posted May 19, 2010 it doesnt really sound like the coil scraping or crinding or anything like that. but i doubt its a tinsle considering hcd3s dont have the sewn tinsles. they are direct 10g wires. retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Neo_frog Posted May 19, 2010 Report Posted May 19, 2010 Have you tried pushing down on the cone lightly to see if it stops? Does it vibrate with the tone being played or is it erratic? Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
troy Posted May 19, 2010 Author Report Posted May 19, 2010 its actually really hard to push the cone down enough to hear anything but it does kinda go along with the tone. high or low volume retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
3ddi31002 Posted May 19, 2010 Report Posted May 19, 2010 i have the same question mine is doing that too and idk what it is they are re audio and the tinsle is not hitting nothing cuz it has that little cushion
J00bles Posted May 19, 2010 Report Posted May 19, 2010 you have oneof two things. 1. a loose dust cap 2. a poorly gaped coil (coil rub) 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel
dwz Posted May 19, 2010 Report Posted May 19, 2010 ya one of the above things happened to me /w the first type-r I had... I heard the rattle and then the sound quality diminished until total shit by 1 week.
