Amp went in protect mode?
chapo123
x2 to being around people that dont know shit lol
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
i feel special that my thread is getting so much attention :D
Ya sorry for threadjacking chapo. Good luck with your troubleshooting bro
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
lol its cool. i like the attention :P
It does control the current because it doesn't allow more amperage then its rated for. The amp will only draw as much as its designed for, that your right about. However a short within the amplifer could cause a surge of power from the battery that is say 150 amps. The fuse will pass that through but the amplifer may not be designed for that load and the internals get fried because of that
You realize your in a pissing match with a amp producer right? King owns his OWN amplifier company...Just a FYI is all
Good day sirs..
93 Chevy Silverado
Crossfire,Dayton
Soon to have 6 Lvl4 15s
DC Audio Dealer and Team Member
If an amplifier pulls more current then it was designed to handle then it is an amplifier issue. Not a fuse issue ;) Typically you will see a large draw in the power system just before the amplifier takes a shit ( goes up in smoke / protect ) or when the install is incorrect. Like lower then recommended ohm loads or a bad install.
I have pulled my head out of my butt, sir. I get what you are saying and it makes total sense. Anyways I learned something today lol.
As for my earlier reply, it came from years of working with crap systems and dumb friends that told me such things.
No worries. just want to make sure the mis-informed are enlightened
Good day sirs..
Puff Puff Pass 8)
All I can say is open the amplifier up and see if anything is literally fried in there.
An Audio Technix 18" Strato on a Kicker KX120.2
My Youtube Bass Vids
Updates When Possible...
I've bought from JBurt09, OrionStang, bcpballer64, LoudNLow931, audioman21, and CJ18 from here (as refs)
Okay so if this was the problem your saying the amp was already a problem but the 60a fuse protected it since the draw was greater then 60a but the 200a didn't because it was less then that but enough to fry the amp?
Team NWSPL
baaudio Build Log
My 1st thought is that the amp was wired too low for a stable operation. a 60 amp fuse would allow it to protect through the fuse long before the amp went into terminal runaway. this doesn't always mean the amp it self will get hot. Sometimes the internals will get hot and fry long before you have a chance to get the heatsink warm.
The 2nd thing I would look at is the system install. Bad grounds and crappy voltage will do a number on a amp quick. a 60 amp fuse would open long before the amp had the chance to really pull some current. Pulling more current then the system can supply can cause the voltage to drop down into unsafe numbers. Having the right size fuse for the amp allows the amp to pull the current needed to make power. This will also cause strain on the electrical system causing voltage to drop. 10v and under causes the amp to do bad things to the switching circuit. Your install is only as good as the weakest point. Often times this weak spot is the ground. It does no good to feed an amp tons of current if it can not complete the circuit in the ground side. You will see a power supply work hard to keep up while trying to ground through any means necessary. Sometimes this can be through the RCA jackets or heatsinks.
You can't "Over current" an amp. Think about this. If you have an amp that only has 40 amps of fusing and a 200 amp alt, Will the additional 160 amps of "current" blow the fuse or break the amp? Of course not. Or else every small 4 ch amp would fry in all these big power setups. Besides, what about all those little 5 amp fuses in the car? does that mean your alt only puts out 5 amps of "current"
Now too much or too little voltage can be a different story. I would say in his case, too little voltage or a bad grounding would be a good start.
And if your "friend" welded a connection to the frame and it melted off then I am going to say he is a horrible welder
No he didn't weld it, he had his ground attached to a part of the car that was spot welded to the vehicle.
  • Who's Online   0 Members, 0 Anonymous, 10055 Guests (See full list)
