yeh my homie has a denali(same as a Tahoe) and he wanted me to build him two enclosure for his 12s but he only had 46 inches to work with in width unlike the 50 i have for my 04 expedition. sucks to hear about scaping the enclosure but you have to measure and plan it out.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Yea I thought I had it set, but the opening for the trunk is a lot smaller than the space where it was going to stay.
Here's some fresh pics...Need more wood, my brother works full time roofing and I needed his truck to get the wood. Can't fit 4x8 sheets in the hoe. Although I could get away with 4x4, I'd be wasting more wood in that case..
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Bottom Box Baffle:
Posted Image
Got rings?
Posted Image
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
glad to see you have regained your momentum man. looks good
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Looks sexy already Im guess the frame you put around the bottom of the box is so you can mount it to the other box with the port that will be at the bottom?
"MY RIDE"
1987 Chevy Cavalier Z24 2.8L V6 -- CB Radio with PA speaker
Head Unit: 7 inch Jensen Flip-out -- Speakers: 4 Visonik 6 1/2s and 4 Visonik 6x9s
Subwoofer: One Audiobahn 18 - Sub Amp: Power Acoustik OV1-2000d 2000 watt monoblock amp --
Battery in back - Kinetic HC600 -- Sub box: Custom built 5 cubic foot tuned to 30 hertz
Coming soon: Bigger Highs Amp, Power inverter
"WhItE bOi AuDiO"
"FEAR THE DUCK"
Exactly. This way they'll still be using the same airspace. The front is still very tight, theres hardly any room for the port. But I'll get er done I think.
Subwoofer Wall
Do you think you will need bracing inbetween the subs or you gonna resin the inside of the box and can you get on aim.
holla
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
I'm going to put MDF braces between each sub. Still no resin on this one. I'm going to go get a couple quarter sheets of MDF because I know that they fit in my car, and try to have this finished up tonight! Trim paneling/upholstery comes tomorrow if I have enough cash for vinyl...
Subwoofer Wall
Thanks man, I'm going down to Irvine tomorrow, and I've made the drive in an hour and ten minutes, and its also taken me over three hours...So basically I need some bass back for the drive...So this means this shit's getting finished today!
Subwoofer Wall
