huh?do-what? Posted June 23, 2010 Report Posted June 23, 2010 Bass above 50 is lame. Low notes are where it's at wtf? bass above 50 is great. But it sucks without low bass. Turn your crossover up a little and see. If you only want to shake things a 1/4 mile away, then yes you are right. If you listen to music that actually has instruments in it, then no. God damn its hot today. My balls are stuck to my leg.
kirill007 Posted June 23, 2010 Report Posted June 23, 2010 Bass above 55-60 should be handle by the midbass. Thinking is the root of all problems... You ALWAYS get what you pay for.
808state Posted June 23, 2010 Report Posted June 23, 2010 wtf? bass above 50 is great. But it sucks without low bass. Turn your crossover up a little and see. If you only want to shake things a 1/4 mile away, then yes you are right. If you listen to music that actually has instruments in it, then no. thas what i wanna do what hz should i look at would 36hz do it? sorry for thread jack but yes prefab box and custom built box to spec night and day difference
Alex K Posted June 23, 2010 Report Posted June 23, 2010 Yeah prefabs are tuned high. Make your own and tune it to low 30's and your lows will come alive. Or seal it. but if you realllly want lows, tune it to upper 20's haha. 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
808state Posted June 23, 2010 Report Posted June 23, 2010 Yeah prefabs are tuned high. Make your own and tune it to low 30's and your lows will come alive. Or seal it. but if you realllly want lows, tune it to upper 20's haha. and watch your type-r's fall to pieces
kirill007 Posted June 24, 2010 Report Posted June 24, 2010 and watch your type-r's fall to pieces It will not fall in pieces. It's just going to control lower frequencies better, and make sure the cone won't launch itself out of the box if u use a bit more power. The only downside is that the higher freqeuncies will be less loud and it will be less loud on the termlab.(but sometimes it sounds louder to the ear.) Thinking is the root of all problems... You ALWAYS get what you pay for.
sseale04 Posted June 24, 2010 Author Report Posted June 24, 2010 thanks everyone. I had a feeling it was my box. any suggestions on where i can get a custom made box?? unless it's really that easy to make your own.. Sam Seale
Jared420 Posted June 24, 2010 Report Posted June 24, 2010 thanks everyone. I had a feeling it was my box. any suggestions on where i can get a custom made box?? unless it's really that easy to make your own.. Its not hard to make your own box. Its hard to make a box that is super efficient and looks pretty too. You should easily be able to make your own box and have it sound better than your prefab and if you tune it lower you will get the lows. I have had a bunch of different setups but I had 2 15'' type rs tuned at 34 hz and on about the same power you have your 12s on and I liked that, Lost a little on high end bass but it liked the lows alot. I upgraded to 4 15s and alot more power and tuned to 36 hz, personally I like the 36 hz better, it seems to be pretty well balanced with hitting a good range of bass. Personally I wouldnt go lower than 32 hz and probably not higher than 36. 2012 silverado ext cab ltz 24" kmc rims AudioQue 2200 Pioneer AppRadio Alpine mrx f35 4 channel Bose mids and highs Iraggi Alt + stock alt in a DC power dual alternator kit Yellowtop+stock under hood 0 gauge Knu wire Big 3 4 gauge stinger (4 chan wiring) 3 DC 10'' LVL3 with LVL4 parts
808state Posted June 24, 2010 Report Posted June 24, 2010 It will not fall in pieces. It's just going to control lower frequencies better, and make sure the cone won't launch itself out of the box if u use a bit more power. The only downside is that the higher freqeuncies will be less loud and it will be less loud on the termlab.(but sometimes it sounds louder to the ear.) very noob here
sseale04 Posted June 24, 2010 Author Report Posted June 24, 2010 Its not hard to make your own box. Its hard to make a box that is super efficient and looks pretty too. You should easily be able to make your own box and have it sound better than your prefab and if you tune it lower you will get the lows. I have had a bunch of different setups but I had 2 15'' type rs tuned at 34 hz and on about the same power you have your 12s on and I liked that, Lost a little on high end bass but it liked the lows alot. I upgraded to 4 15s and alot more power and tuned to 36 hz, personally I like the 36 hz better, it seems to be pretty well balanced with hitting a good range of bass. Personally I wouldnt go lower than 32 hz and probably not higher than 36. Yeah, I think I figured out that I want the box to be tuned around 30hz after taking to a few people. I dont like high bass anyways. how do you get the dimensions for the wood to make the box? thanks Sam Seale
