audiopipe 1500
CNF Kevosinn
I have the audiopipe 1500 and had a question about wiring. If I have 2 subs wired seperate from each other at 1ohm and I put one sub to 1 channel and the other sub to the other channel I should be getting 750rms @ 1ohm from each channel right? yes I know im not gunna get exactly 750
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
The AP 1500 2 channel or Mono?
If it's the mono, wiring each sub to one and putting them like that will equal a final ohm load of 0.5Ω.
It'll take it but get hot as hell, and void your warranty. LMFAO
2 channel
Skyhigh wire
some batteries
Slight thread jack...
From what I've been able to see, the AP amps have a good $ to watt ratio. But do they do anywhere near rated?
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
2 channel
OP: Not exactly...
I was going to put it all in one post, but then you may miss it, so yeah...
2 channel @ 4 ohm--160w
2 channel @ 2 ohm--320
bridged @ 4 ohm--640
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
Skyhigh wire
some batteries
Dude, go to your amp, pull the model number, and give it to us. That's the easiest way we can help you.
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
its has 2 + and 2 - but thats just to make it easier to wire the shit, its 1 ohm stable, so yes, technically its 750~ per channel i guess you can say, but if you run 1 ohm per side, its .5 ohm
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
  • Who's Online   0 Members, 0 Anonymous, 1007 Guests (See full list)
