so i moved my computer upstairs and i have my wireless router set up and working fine
now its upstairs and if i plug my modem directly to the tower it fine and connects but when i connect it to the router the wi-fi works but the internet on my desktop dosent connect what could be the problem
2 jl audio 12w3's sealed
soon to be 4 level 3 15's
blow through
all dc audio
You have to get the Mac address from your computer then log on to your router and put your Mac address into the router.
The reason its not working is because the cable company stores your Mac address and that address get internet. A new router will have a different stock Mac address so you need to change it to match your computer mac address then you will have internet back.
first question, what make is the router?
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
x2 call ur internet provider or just use the ethernet cable....had the same problem with comcast and my ps3 i need to reset the modem every time i wanted to play online, so got a router and used a ethernet cable, wireless too but u need to add a bunch off different internet information for it to work :pardon:
