There was an extreme vehicle that burped a 160.9 with 16 6x9s in a wall.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
interesting, i had not heard much about 6x9s except for one guy that had some I believe tang bangs, and had 6 in the rear deck boxed in from underneath
im going to try and borrow a friends amp tomorrow as he wants me to check to see if his sub works and he does not have any wiring ran and mine is just sitting there, so maybe i can get a vid tomorrow if he stops by
well found out my amp wont come til nexct week, its being mailed out monday
i had an idea to change the boxes into 1 box after i test the t-line boxes, and i was looking at 12volt.com and apparently my idea for a new box to merge these two boxes together is actually called a three chamber dual reflex bandpass box now i dont know how that will affect the 6x9s but after i test the t-lines, im gonna test that
seems fun to do
i may even leave the internal of the box as a t-line, but then that would defeat the purpose of testing anew enclosure i think, not sure how a three chamber dual reflex bandpass t-line would sound, but sounds fun to me
Sounds interesting you're trying out these different enclosures but I would at least get a subwoofer, maybe hit up Parts Express and get a couple of 6 1/2 subs. I'm definitely interested in the outcome :good:
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
No better way to learn than to experiment. I'd like to see how these turned out, post up once you get your amp. And f*ck the haters!
97 Maxima SE
Bunch of shit going in, check out the build
Pretty cool dude I did alot of experimenting with 6.5s and 6x9s you can get some pretty good bass outta them if done correctly, but its mostly experiment then rebuild.
Bandpass is fun as a mofo with 6.5s
Current
Ford F350
Alpine IVA-W505
2x Diamond s600
1x Diamond S400
2x RF T1500-1BD
1x RF T600-4
2x AA Havoc 12"
DC Power 230XP
1/0 throughout
Up Next
95 2dr Tahoe
Head Unit= Alpine IVA-W505
Components= 2 Diamond S400, 2 Diamond S500, 2 Diamond S600
Woofers= 2 10" Diamond Hex, 2 12" Diamond D9
Amps= 3 RF T1000-4
Processor= 2 RF 3sixty.2
Subs= 4 18" AA Mayhem
Amps 4 RF T2500-1 BDCP
7 XS Power D3100
3 DC Power 270+
this will be funny when it powers up, im guessing smokey smoke in under 30 minutes
funny, you know nothing of my build , try reading it more carefully
and a FYI on my electrical i havent really talked about it so you dont know what i have, next time you bash get your damn facts straight
the only thing I can do is laugh. your a joke. you actually think people will buy memberships just to see your build, dont flatter yourself. The most sensitive guy on the forum is trying give shit to someone else, lol
OP, besides just for fun, do you plan on using these in your vehicle?
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
if they sounded good i may keep them in a box, i had them previously mounted in the rear deck in free air, with about 200rms to each, i stated 400 earlier but didnt think that the 400 was to both 6x9s not just 1, they are rated at 150rms and 100 for daily use, but i also read at many places that cadence underrates there stuff sometimes so i wasnt too worried at the 200 rms
they sounded awesome in a free-air environment, shook rear and side mirrors a lot, mainly on put on by kanye west, but depending on how it compares to them being in the box, ill either put them back in the rear deck or keep them in a box, i also have 2 15s in the trunk, once i get a new amp to run them also, so we will see
to ericR, did you mean get a sub to put in the already made 6x9 boxes or just get a sub in general and not bother with the 6x9s
regardless of how these will be used in my car, they will still be getting hooked up to the same amp, so depending on if i can get these to a 2 ohm load, since my 15s are 2 ohm load, i may run them both off that rockford fosgate amp, until i get a new one for the 15s or would that be too much load on the amp
amp does 380 by 1 at 4 ohms and 500 by 1 at 2 ohms, so its mono amp but has 2 pos and 2 neg inputs, so if i got all wired at 2 ohms, then they should split 250rms for eachs et meaning each 6x9 and each 15 would be getting 125 rms, am i right
they previously ran on a sony xplod i borrowed from a friend to test them at time of purchase and the sony only gave them 125rms, so i know they still sound good even though its a 4th of what the sub can handle
will the amp be okay with that, i know im trying to squeeze a lot out of a little, but just want best sound i can get and id like to use all i have
comming from the guy who wants to run 18v 10k @.25 ohm on 4 18s? with not much of an electrical system
^^Bahahaa.I just had to make sure no one missed it.
lol, yea i mentioned that in his post before he took it to membership only section, i didnt see a reply on it though
oh well, my amp is being shipped out today, or im gonna have to molly whop somebody =)
