Amps Overheating Majorly Need Advice on Cooling
Have someone install fans inside the amps?
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
those xt1600's just run hot as shit man.
Id swap it out.
i use these fans http://www.pricedbelowmarket.com/computer-parts-hardware-fans-delta-electronics-inc-afb0612ehe-fan-209316.html
Best fuckin fan ever.
pull the back plate off the amp, and stick 1 of these under it.
Id swap it out.
Here's what I got... I have 2 6.5's, 1 5x7 and 1 tweeter on each channel, to a 1.9-2.0 ohm load... Any ideas on what amp to use that would run cooler? I was thinking about the AQ4x90 amp. IDK if it would run cooler or be any better of an amp??? Does anyone here run a AQ4x90 at 2 ohm stereo and how hot does it get?
Hmm, here's my idea, take the tops of the cases off of the amps and cut out a new plexiglass one, and install in and out fans on them and call it a day. Maybe put a couple of ccfl's in the amps then to give them character. add a relay to the remote line to turn on all of the fans and amps, otherwise water cooling would be badass but a pain in the ass. Maybe, if you are going to cut a hole in your truck, just run some pvc piping to an ac output to put some ac back there...
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
forgive me for not reading though most of this but here is my take on it...
the airspace back there is very small. its sealed off by the hatch and by the box so air is not circulating. fans in the area will help but without a supply of cool air itll just get hotter and hotter and your just blowing hot air onto hot amps. you need a way to get cool air in and hot air out. a decent sized "push/pull" fan setup in the floor would do it. dont make it something that requires you to be driving for it to work.
and the AC ideas... what about at night when you dont have the AC on, turn the air off or maybe even the heater on. plus you dont have a good way to get the old hot air out of that chamber. just doesnt sound reliable to me.
I was going to run the rear roof ac vents back there, but needed every bit of room for cabinet... I need to upgrade that amp because it is not that good of an amp in the first place... Just don't know which direction to go with the new amp... don't want the same problem... Plus... I am broke as hell now! LOL! HEY EVERYONE?! ORDER SOME DECALS SO I CAN BUY ME A NEW AMP!!!! :pardon:
The only spot I have in the back is under the epicenter to the left of the batteries.. BUT.. the frame is DIRECTLY under it... Cannot go through the floor... thought about making a slot/vent between the floor and the back hatch... I also thought about running a 4 inch pvc through the cabinet from the front to the back amp rack, but it would displace too much in the cabinet... It is JUST BARELY enough room for 6 15's behind the back seat... I can't go that route... As I said before... painted myself into a corner I think...
is there a way you can run some sort of ac tubes under the car, then bring the up inside?
2006 Nissan Z Track.
My Feedback Thread
there has to be a way... in the edges of the box that run front to back do you have 45*s? you could take those out and add 2" pvc then glass them into the edge to make a new 45*. i know 2" isnt much but its better than nothing. put a fan on each end of the pipe to make as efficient as possible. one tube blows, the other sucks.
you could cut holes in the hatch but you would need a cowl to keep water out... maybe you can use the lip just above the license plate. cut a wide hole there.
There's no room on the floor to get a duct into the back... the frame sits right where the only free spot is...
I might be able to do the tubes through the back hatch and get cowls... I am going to look into that as an option...
  • Who's Online   0 Members, 0 Anonymous, 2393 Guests (See full list)
