703autosport Posted July 29, 2007 Report Posted July 29, 2007 Thats right, Im thinking outside the box about running six 8" subs in place of my current set-up of 2 Xtant X2 1244's but dont know which are the better choice. Here are my choices; Arc Audios- Arc series 8d4's, Diamond Audios d308's, Rockford Fosgate's new p2d48's/their last years version of the p310d4's since they stopped making them, or possibly fosgate p210d4's even though their 10's...I found a crazy deal on them at $50 a pop. Im looking for a balance between sound quality and spl that can possibly top my xtants and Ill have them running off an xtant 1001dx(not sure weather to run them sealed or ported yet, any suggestions?). I want to do something differant which is why Im looking into 8's and I have to go with one of these choices because Im in a mobile training school in Jersey that gets half off these brands for students. Let me know your opinions, good or bad and if you want the specs on the subs I can post them up as well. Thanks
wfeld Posted July 29, 2007 Report Posted July 29, 2007 8" subs??? why?? 15" re sx 4.1 cub at 33hz box by coolwazabi
703autosport Posted July 29, 2007 Author Report Posted July 29, 2007 Just because its something differant, everyone and their mother has 12's and 15's but you dont see 8's often... If I design it right, the look on peoples faces alone would be worth it when they find out that Im only running 8's and out dropping them... only thing Im worried about is that it would be built mostly out of glass, my current set-up hits 142.4. Also cause I beleive that 8's are more responsive than 12's+ but Im sure some people might disagree
Dale Posted July 29, 2007 Report Posted July 29, 2007 could you post the specs? that would surely help
Eric B Posted July 29, 2007 Report Posted July 29, 2007 8's are old school, they can get low too, ive heard 4 8's before and loved it 2007 Chevy HHR LT UNDER CONSTRUCTION 1st Place Loud N Low 2010 MWSPL Finals 3rd Place Xtreme 3 2010 MWSPL Finals
703autosport Posted July 29, 2007 Author Report Posted July 29, 2007 Yea Ill post what specs I have, itll take a few to write it up
703autosport Posted July 29, 2007 Author Report Posted July 29, 2007 Rockford Fosgate P38D4(last years model)- 250W Recommended RMS Power 500W Peak Power Handling 2" Anodized Aluminum Voice Coil Former Embedded Tinsel leads lower resistance Massive 57oz. magnet assembly Parabolic Triangular Geometry cone support system Precision 2-piece basket is cast from aluminum alloy Reversible concealing ring Large roll surround Sensitivity: 81 dB Frequency Response: 39-250 Hz Impedance: dual 4 ohms subwoofer wiring options Rec. Sealed Box Dims: 0.30 - 0.30 cu. ft. Rec. Ported Box Dims: 0.63 - 0.63 cu. ft. 5 1/8" Mounting Depth 6 7/8" Cutout Diameter Rockford Fosgate P2D48- Custom 10-AWG nickel plated push terminals Extended pole piece and bumped backplate High density poly-foam surround High-temp voice coil with spun-laced Nomex® re-inforcement collar Linear spider with embedded 16 AWG tinsel leads Parabolic injection molded ABS/Acrylic dustcap Sturdy 16 gauge compound-bend frame Thermoformed polypropylene cone Vented spider cavity Impedance 4-Ohm x 2 Power Handling 200 Watts RMS 400 Watts Max Sensitivity 84 dB Motor Size 38 oz. Double Stacked Voice Coil Diameter 2.0" 4-Layer Speaker Connector Dual 10 AWG compression Mounting Depth 4.625" Rec. Sealed Enclosure 0.23 cu. ft. Range: 0.20 cu. ft. - 0.30 cu. ft. Rec. Vented Enclosure 0.65 cu. ft. Shipping Weight 10.00 Lbs. Rockford Fosgate P210D4(last years model)- Parabolic Triangular Geometry cone 60 oz. double-stacked magnet Compliant linear spider Precision CRS basket is stamped from cold rolled steel 2" anodized aluminum voice coil former stays up to 100° cooler Large roll surround allows for 20% greater linear excursion than standard surrounds Insulated tinsel leads Custom compression terminals accept up to 8 gauge wire Mounting Depth: 5.6" Cutout Diameter: 9.25" Rec. Sealed Box Dims: 0.65 - 0.65 cu. ft. Rec. Ported Box Dims: 1.00 - 1.00 cu. ft. Sensitivity: 85.8 dB Frequency Response: n/a Recommended RMS Power: 250W Peak Power Handling: 500W Arc audio Arc 8D4- Dual 4 ohm 150 watts rms / 300 peak One piece molded rubber surround High temp black anodized voice coil Progressive flat spider Extended bump plate Impedance : 2 or 8 ohm Resonant frequency : 24.7Hz Sensitivity : 85.6 db RMS power handling : 150 watts Electrical "Q" : .367 Mechanical "Q" : 3.572 Total "Q" : .332 Equivalent volume: 1.55 One way linear: 15 mm Mounting depth : 4.75" Optimum sealed enclosure : .35 cuft Ported enclosure : .6 cuft Diamond Audio D308- Textured Copolymer Cones with Aluminum Dust Cap Nitrile Butadine Rubber (NBR) Surround Extra Heavy Gauge Stamped Steel Basket Optimized Spider with Balanced Linear Suspension Integrated Tinsel Leads Venturi Vented Basket Vented Pole Piece Double Stacked Ferrite Magnet Available with Dual 2 Ohm or Dual 4 Ohm 2.5" Voice Coils Power Handling NOM/MAX: 200/400 Watts Sensitivity (2.83V/1m): 83 dB SPL Freq. Response: 30-500 Hz Mounting Depth: 4.1 in. Diameter: 7.4 in.
Ray Posted July 29, 2007 Report Posted July 29, 2007 I run 8's. The biggest problem with running small drivers is finding some that can do what you need them to do, get loud and low. The ascendant audio 8 and the digital design 8 are the 2 loudest 8's that ive ever played with. aa8 was loud ... had 6 of them off 2500rms and did a 150 legal. but didnt have the quality I was looking for in sound Now i rune the dd 8's just 2 of them 800rms, and it is plenty. Now i havent metered them yet but my guess is that they are doing a 140 on music, not bad for 2 little 8's. When I demo them I always ask poeple to guess what I have in there, and i get it all.. 2 12's, a fifteen, 2 badass tens etc.. they never guess 8's have fun. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
roscoe1129 Posted July 29, 2007 Report Posted July 29, 2007 when JL came out with their 6.5 subwoofer I did 30 of them in an extended cab ram. They got pllenty loud and was a real shocker to people, I think it metered around 145 on the old termlab, so probably 142-3ish on the new TL.... Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
