So I was driving to work and it was raining very heavily, so I put my jeep into 4wd Part Time just for shits and giggles. I was driving and it felt a little weird but i just figured it might be normal.
I pulled in to the parking lot and into a spot and when i turned, the fron end started freaking out and chugging and my wheel was jerking back and forth,
it felt like there was resistance on the wheels as if they were getting caught or rubbing on something but I looked and nothing looks broken or seems to be rubbing. I was told it could be the CV joints?
Any ideas guys?
Thankis in advance.
If i left anything out that you need to know, I'll be checking frequently.
Edited by Rolladoedoe
formerly known as Jaylor Swift
well MINE when i put in 4wd it does the same time, say when ur pulling in or backing out of a parking spot and turning. i work at discount tire and ive been in alot of vehicles that do that. usually ONLY when you turn sharp tho
It always chattered a little bit while taking charp turns but nothing ever crazy like this. It did it for a few feet while going straight too and made some noises.
Shouldnt do it going straight but any 4wd Ive ever been in does that when the wheel is cut all the way or just about all the way.
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
my girlfriends step dad had a jeep liberty that did that. i swapped the transfer case and it stopped. turns out the chain inside was stretched and jumping teeth. after it was out u could turn the front output shaft and hear the chain slapping the case.
Edited by t-money
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
Well i dropped it off at a garage just to be safe. Hopefully it doesnt end up being anything costly. It was really bad when it was happening. i was worried to drive it.
Well i hope this isnt the (transfer) case. LOL JK! lame joke. But really. I just got money to buy new equipment and then this happens.
CV Joints, driveshaft, wheel bearings, transmission or tcase. Most 4wd's will "cut" across the pavement when it's dry and you're turning... This is also a sure fire fucking way to screw somethign up. Not supposed to make noise on straights... mine has a little hum that's it
Well guys, it turned out to be an outer CV joint. There goes half my subwoofer budget. =/. :bull:
