Where's the best place to ground your syetem?
BradlyLovesSpl
to the chassis of the vehicles B)
The chassis has the most negative current. All you have to do is clean the surface and get rid of and paint that is there =) Hopefully someone can give a full explanation 8)
Neg on a battery is good, Only if the negative on the battery is grounded to your frame or chassis with good wire preferably 1/0 gauge. Personally I ground my amp to my rear battery since its like a 2 foot run from amp to battery and thats grounded to the front battery which is grounded to my frame which I sanded, drilled and tapped. Very solid connection to the frame. If you dont have a tapset a nut and bolt will work as long as you sand it down to bare metal.
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
also for all vehicles that don't have frames (unibodies) I always trust stock ground locations. good thing about them is theres already a bolt there and you know it works.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Make sure you ground to the FRAME of the car. Too many people make the mistake of grounding to a piece of sheet metal. A good ground is VERY important to a good electrical. IMHO, you're only as good as your electrical. I upgraded my electrical before I bought my amp or subs.
The King.
What about the seat bolt? Would that work?
2005 Dodge Dakota Laramie 4.7L V8
Hifonics HFi1500D
DC Audio Level 4 XL 12"
Yellow Top Optima Battery
_________________________________
Not using in build
US Amps MD3D 2000w @ 1 ohm
Power Acustik 5 Farad Capacitor
__________________________________
Soon to come
DC Power or Iraggi 260a Alternator
Rockford Fosgate T2652-S
Rockford Fosgate Power T1S652
Hifonics HFi100.4
the alt charges the battery and the wire really only needs to be able to handle the output of the alt. if you ground the amps to the battery there is no current from the amp that goes through the chassis so you dont NEED more wire from battery to chassis. if you ground the amp to the chassis then you need to upgrade the battery ground because all the amp's current needs to go through that wire.
remember that DC flows from - to +. that ground is just as important as the power wire.
  • Who's Online   0 Members, 0 Anonymous, 2100 Guests (See full list)
