I've had these for a while now, and according to the JL site they are 200w rms, but on woofersetc and sonic it says they are 350wrms/700peak...anyone wanna help me out here lol?
http://www.woofersetc.com/p3173/13W1v24--JL-Audio-13"-700-Watt-Subwoofer.htm
says 200 watts on here
http://mobile.jlaudio.com/jlaudio_pages.php?page_id=172
And here down all the way at the bottom is a power graph http://mobile.jlaudio.com/products_subs.php?series_id=17
Edited by Slawsen
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
Its says 350w on the JL's site....
But if you look at the power chart below it apart in the specs that is the peak rating from them...
Edited by wL<3bass
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
looks dead on you just didnt check for the specific subwoofer that was on the woofer site
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
call JL and ask.
Was busy
No idea what you're trying to say....
So sites like sonic and woofersetc are giving false product information?
Edited by Slawsen
00' Nissan Xterra
you didnt go to the specific *older* model that is what i linked you, the rms says 350 just like the woofersetc site you linked....
Edited by Team_DC-Derrick
Team DC Audio
The one you linked is the same one I linked, it gives 350 watts as peak power handling, and at the bottom is the power chart...
00' Nissan Xterra
from JLs website for the 13W1v2 woofer
Free Air Resonance (Fs): 20.9 Hz 21.9 Hz
Electrical “Q” (Qes): 0.406 0.462
Mechanical “Q” (Qms): 6.936 6.774
Total Speaker “Q” (Qts): 0.384 0.433
Equivalent Compliance (Vas): 6.131 cu. ft. / 173.51 liters 5.982 cu. ft. / 169.29 liters
One-Way, Linear Excursion (Xmax)*: 0.475 in. / 12.1 mm 0.475 in. / 12.1 mm
Reference Efficiency (no): 0.375% 0.369%
Efficiency (1W/1m)**: 87.71 dB SPL 87.65 dB SPL
Effective Piston Area (Sd): 105.774 sq. in. / 0.0682 sq. m. 105.774 sq. in. / 0.0682 sq. m.
DC Resistance (Re): 4.114 ohm 6.803 ohm
Nominal Impedance (Znom): 4 ohm 8 ohm
Thermal Power Handling (Pt): 350W 350W
Driver Displacement: 0.05 cu. ft. / 1.42 liters 0.05 cu. ft. / 1.42 liters
Net Weight: 11.21 lbs. / 5.08 kg 11.21 lbs. / 5.08 kg
taken from woofersetc
* 13" W1 version 2 4-ohm subwoofer
* Maximum Power Handling (Pt): 700 Watts MAX
* Continuous Power Handling (Pt): 350 Watts RMS
* Nominal Impedance (Znom): Single 4 ohm
* One-Way, Linear Excursion (Xmax): 0.475 inches / 12.1 mm
* Nominal Diameter: 13.5 inches / 345 mm
* Overall Diameter: 14 inches / 356 mm
* Mounting Depth: 5.9 inches / 150 mm
* Net Weight: 11.21 lbs. / 5.08 Kg
* Driver Displacement: 0.05 cu. ft. net / 1.42 litres
* Rec. Sealed Enclosure: 4 ohm: 1.5 cu. ft. net / 42.5 liters
* Rec. Ported Enclosure: 2.625 cu. ft. net / 74.3 liters, tune to 26 Hz
JL Audio 13W1v24 JL Audio 13W1v2 4 13" 400 Watt Subwoofer
Team DC Audio
Lol then why the hell does the chart at the bottom say 200 range is 'optimal'...i fucking hate jl
00' Nissan Xterra
no, the page I linked and the page you linked are 2 different pages... if you go look they are different
you linked the one talking about the NEW 13w1v2 and i linked the one talking about the one from the woofersetc site
Team DC Audio
  • Who's Online   0 Members, 0 Anonymous, 687 Guests (See full list)
