jsut bought a 100$ car. 95 impreza. it wont start. i replaced sparks and wires, fresh fuel filter, cleaned the throttle body, clean the injectors, checked the fuel pump. any ideas on why she wont start?
Is it not turning over? Can you hear the relay when you turn the key? Maybe a bad starter solenoid
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
And you've replaced the spark plugs and wires? Checked the distributor cap?
under construction
u hate c-fizzy?
Bad MAF sensor maybe? are there any leaks in the intake piping? That's the only thing I can really think of, otherwise search for a good subaru forum, you might be able to find a forum just for the impreza, those guys would probably know the exact problem. That's all I got really :shrug:
Need Test Tones/Sine Waves? Click Here!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Pioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE Audio
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Hit me up on Facebook, if you want
Sorry, haven't done much work on boxer motors, but I say x2 on the subaru forums. You might have better luck there.
under construction
u hate c-fizzy?
got it to start! but theres no power, i can floor it and its gutless, any ideas? btw there is a strange knocking noise, not rod knock, seems to be comeing from around the intake manifold.
Posted (edited)
You got timing issues. Thats why theres no no power, and the knock is probably the valves staying open and the pistons hitting them. Get the timing right or you'll be buying new heads on a car thats probably not worth it.
EDIT: There could be valve or piston damage already, too, causing power loss.
Edited by OrionStang
SMD Super Seller
My Feedback Thread
Posted (edited)
If its backfiring through the intake that could sound like a knock.
If there is Deisel fuel in the gas that will cause hard starts, poor running and lean backfires. I would get a fuel sample, and double check the spark plug wire order.
34
12
front of car.
plugs and ignition coil are situated in same direction.
Edited by toytrkdrvr
  • Who's Online   0 Members, 0 Anonymous, 2827 Guests (See full list)
