Hello everybody,
Im looking to get a new amp to power my 12" Kicker SoloX i own. I will be replacing a Precision Power PC2350 amp and i was recommended an Audio AQ3500 d.1 from a few users on this forum. My question is for those who own this amp....
1.) Is this amp really great sounding?
2.) What size batt and alt do you have for running this beast?
3.) What did you hook the speaker up to (resistance level)? (NOTE: my kicker solox is a dual 4 ohm coil so i can only drop it as low as 2 ohms in parallel)
Any help please get back at me.
Thanks once again
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
1. YES this amp puts out a very clean power
2. I have 2 of these amps with 4 XS Power D1400s and a DC Power 350XP Alt
3. I have mine strapped to 1.4 ohm so that equates to .7 per amp. At 2 ohm that sub will most likely be begging for more power. see if you can get a recone of dual 2 ohm or dual 1.4
Ok. Thanks for the reply. But since the woofer handles 2500 rms and the amp puts out 2600 at 14.4v it should be a decent match right?
Hell the amp i have now is bridged to 1400 watts and the woofer sounds great but its not loud enough for my preference, and plus i want to feed the woofer the most it can and not really make it exceed its rms (although im sure it will) but im not doing sound comps too much, more like music on a daily basis at very very loud levels.
bump for anybody else who uses an auqioque (preferably the aq3500d.1 amp)
you gotta factor in power loss through the lines, impedance rise and much more so you may want to get the coils changed over to a lower impedance...its better to have too much power and back down than try to make up for power by cranking the gains. much easier on the amp and more efficient on your electrical system. also you gotta make sure the box is right to handle that kind of power and wont hurt the sub if its tuned too high to cause bottoming out
NoFearX18 said:
trainman0978 said:
Chode = win
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
I don't have the aq3500.. but I do have two of the aq2200s..and they are at 1/2 ohm. Each...I have a extra battery on each amp and a extra 240 amp alt just for the subs...and these amps do well..no troubles. ..very good amp for the price
169 shipped on ebay for a recone.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
Get a kicker 2500.1, it does rated power at 2 ohms (what u need), and is a BEAST of an amp. But if your looking to upgrade in the future, get the AQ
F/s: 2 custom made boxes, for 1 12" and 2 12" hit me up I'll let em go cheap
  • Who's Online   0 Members, 0 Anonymous, 2099 Guests (See full list)
