I have a wiring question
so I have 4 kicker cvr 12's in my jeep running off a ap 30001d
I have each set of 2 subs, wired to 2 ohms.
one set per channel.
but I went to test the ohm loads on each set with my multi meter, and it fluctuates like crazy.
it'll wind up to 2 ohms slowly, like normal, but then like keep climbing all the way up to around 4 ohms.
what would cause it to fluctuate so much?
I know the wiring is correct cause I always use the diagrams on the12volt website..but does anyone else have any input?
Are they hooked up to the amp when you test them?
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Don't check them while they are hooked up to the amp. If they weren't it's either your DMM or they are starting to burn up.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
2 270a Mechman Alts
probably a bad dmm
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
I tried it both hooked up, and un hooked.
they're going bad cause they're brand new.
and I have tried another meter,and it did the same thing
Pretend U never tested them and sell them as new? jk of course
Try to get a refund/replacements if wat ur saying is true.
Also are u trying each individually to see if its all the subs that are going crazy or just them linked up. Could be 1 or 2 bad subs and maby not all of them.
  • Who's Online   1 Member, 0 Anonymous, 1352 Guests (See full list)
