the misses wants a system. I've got some leftover gear I can install but space is at a premium (mini cooper)
Here's what I'm thinking
1 Alpine Type R 12 ported in 2.5cf with 500 watts
OR
2 Alpine Type 2 12s in 1.75cf per woofer sealed with 500 watts
which is gonna get louder? I'm way too busy to build a bunch of boxes and test.
Alpine F1 Status
DD CS6.5 x2 Front Stage
DD 9512H
DD M4a @ 2 ohm
DD S2b @ 8 ohm per channel
I run high ohn loads for MASSIVE headroom and cleaner SQ
270amp alt
D2400 up front
D3100 x2 batter in back
the 2 woofers
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
the two subs because double cone area and same power. if you had the one sub on double the power ported it might be louder. depends on car and box tho.
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
she used to push a Accord with 4 10s she likes to bang!
I'm redoing my truck and she'll eventually get my BTL 12
Alpine F1 Status
DD 9512H
DD M4a @ 2 ohm
270amp alt
D2400 up front
............. Just making sure.... I did write single 12....
Yep it's there..
All day long.
Two 12s. The difference would be small but noticeable
x2 i used to have 2 kicker cvr's in a sealed 1 cubic ft. each on 500 rms (250 each woofer) and then i took em out and replaced it with a single jl w1v2 on 500 rms what i have now and the difference wasn't huge but it was noticeable the jl is a little louder but i hate pushing it as much as i abused the kickers
edit: btw. single 12 is in a ported box tuned to 45hz wished it was lower
Edited by jl_audio
Yep it's there..
All day long.
x2......
wait ill check again for you........(scrolls back up a tad).......
yep... ray said it...
due to the larger box and less resistors(coils) the power will be consumed more efficiently... there for should be louder if done properly
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
  • Who's Online   0 Members, 0 Anonymous, 870 Guests (See full list)
