I'll design it for you .... 13.5 cubes tuned at 35 175 square inches of port.
go build
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
glad the squealing went away!
need to go lower on the tuning lol im think more like 32 :-)
Did alittle something this weekend...after along day and a good cuss fest the damn new alt is in :yahoo:
Mechanically the teg has been a bitch to work on, the old alt needs to come out and so does the belt to replace it. We'll why would it be easy right? just wouldn't be fun <_< Also DID replace the other belts while im at it
Took the old out here some comparisons...
unbolting the old is easy, getting it out is another story, i also did it with out removing the axle assembly.
you start off like usual, take battery cable off, loosen alt and take belt off then...
1st unbolt the bracket that holds the driver side axle assembly, its half way on it.
lets you slide it out alittle
remove front tires, then remove this cross brace that thats part of the suspension
looks like this
then remove the old alt out and replace it with the new. here some video, took a while to figure out how to take it out this made it look easy lol
When installing the new HO alt, since its for a different acura the upper bracket needs to be cut alittle and then washer put on the the bottom bolt everything else should be the same
Put back all the sht and it should work like a champ!
All done!
It has a voltage regulator so the voltage stays at 13.5, so far no squealing or anything seems to be running good. once the system is in then the thing will come to life
Thats it for now!
the new belt looks a tad thin??
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
Good shit
hell yeah, im glad the thing wasnt bigger or the axle assembly would of had to be take off.
pulley is smaller but wider then the stock, i can only use the smaller belt :pardon:
Wow. You saw all the shit I had to go through to get my alt in. This makes it look like I had a walk in the park! Lmao. Guessing Ohio Gen contacted you back and mentioned the voltage regulator?
yeah, i didnt think it had one lol
yeah called them up and they said from what i described its worked perfectly, should stay at 13.5 since the batterie is charged once it needs to charge more it will do so. also the reason it does move around when i hit the gas
i might still try to change out the belt but for now imma let it be, see how it goes
Little update, havent done sht to the car other than put the doors speakers on the door panel instead of behind it
Amp should of shipped out this wk got this email earlier this wk
Txted Robert and hopefully next week we can build the wall! :woot: if not for sure the wk after. Short notice beacause were not sure on the work schedules but as long as he has time ill call off work :pardon:
Now for some random pics (car is dirty)
Hey fucktard, where are you building at?? ill come give a hand as well if im free
ohhh so you offer to help him but not me i see how it is lem
