XS Power
i was looking at getting a couple of batts from xs but can someone please explain the difference in the s series and the d series?
is one better then the other for car audio or are they the same?
this is the difference... i asked nate the same thing and he informed me this...
"The s series batteries have a reinforced steel casing whereas the d series just has the plastic casing."
So the s series has a little more integrity than a d series. I own an s3400 batt under my hood now and i just ordered my d3100 from nate today. xs power batts are awesome and i believe they are under-rated. I had my s3400 tested when it was new and it tested at 1060 crank amps. I just had that same battery tested about 2 weeks ago and it tested at 1200 crank amps!! Im using that battery to power a 1400 watt rms amp at 4 ohms and it will let me crank the power without the engine on for about 1 hour before i have to turn the engine on to charge it back up. xs power is one hell of a battery to use.
Hope this helps clarify the difference for you!
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
  • Who's Online   1 Member, 0 Anonymous, 2694 Guests (See full list)
