This is what I use at my Dad's shop... This thing is a monster...
Freud FT3000VCE 3 1/4HP Router
Use this for smaller projects...
Craftsman Professional 28084 2 1/4HP Router
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Just checking out Woodcraft now.. Little overwhelming considering theres 100s of bits. Are there general sets with the most commonly used, I cant find them.. Yet..
Another thing, when Tracing existing holes, Im gonna want a flush bit with a bearing, But like you said , to make notches for the carpet, obviously the bearing cant be on there, so what bit will I need to dig down that extra 1/8".. I see a bunch of flush bits with blades on the bottom of it, but without a bearing, doesnt it dog into the wood?
Here is the ones i use.
First is the down spiral cutting bit. This is used to cut the baffle as well as the cutout for the flush mount. On the flush mount, it will poke through a little to create a pocket in the sub baffle.
http://www.woodcraft.com/Product/2081560/31617/Freud-Downcut-Spiral-Router-Bit-12D-114CL-12SH-Freud-76108.aspx
Roundover bits are to make all the edges of the box nice and purty ( side note ) Do not use these if you screw your boxes together. The bit will NOT like the screw heads ;)
http://www.woodcraft.com/Family/2008063/WHITESIDE-Roundover-Bits.aspx
Rabbet set is used for making a lip in wood. Like when having two existing baffles and you want to flush mount the sub.
http://www.woodcraft.com/Product/2001864/3420/Rabbet-Set-12-SH.aspx
Flush trim bit is used for a few things. first would be making a second baffle over and existing cutout and wanting them to match in cutout size, but no flush mount. Also used to cut patterns using templates. Last thing to use it for it to trim any over hang on the edges of a box. For example, if you get everything together and the top overhangs a little bit, you can cut off the extra using the side of the box as a template
http://www.woodcraft.com/Product/2004655/7487/Flush-TrimPattern-Cutting-Bit-12-D-x-112-CL-12-SH.aspx
There are a few others I use, but those are just for some trim and detail work I like to include in my box building.
great list man, thank you!
Questions.. The spiral bit seems like it would chew up on the wood on the flush baffle, unless the Jasper jig holds it perfectly in line?
And what sizes should I go with for these, unless the ones you linked are the diameter, and depth sizes I would want
Edited by comatoastedlush
Without a doubt Festool makes a kickass product, but unless it's in your hands everyday, it's not a cost effective solution for around most DIY builders or shops. I use the hell out of my router and in my years I haven't burned up enough routers to justify the cost of one Festool.
The spiral works great. As you use your router more and more you will get a feel for speeds and movement to keep different kinds of woods from getting tearout. MDF is very forgiving.
As far as size goes, you want bits that 1st match the router you get. I use mostly 1/2 shanks in my router. Depths will depend on the thickness you are working with. My spiral is 1 1/2 My rounder is a 3/4 for using MDF and my flush is a 2" for cutting 2 baffles in one pass. Bout the only thing I use my Rabbit for is plexi flush mounts to the box
Yeah Bill thats true i know, but he wants feedback, he gets feedback :D
Im a festool-fanboy lol
Ive used a few Frestool products.. Good , Hell yea.. Practical? lol not for me :) I have a 6 yr old Makita, and 2 yr old Craftsman circ saws with the thick shoe, and use them both on the job everyday , and they both work great, But I can still understand your fanboyism for frestool.. They make awesome stuff
