Who here can play 25hz, loud and clean?
incase you missed it. :)
Where is the other video! You promised LOWAH!
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
I am also keen as mustard for the vid. Sinead O'Connor screwed is somthing I would play for some jaw drops. Where can I get this track from...
Systems:
Fun Car:
Deck: Alpine CDA-9887
Front sounds: Alpine SPR-175A x2
Front power: RF T400.2 Benched at 265x2 rms @ 2ohm
Subs: RF T1 10 dual 4 Ohm x1
Sub power: RF R500.1
Box yet to be built.
All in a Mazda 323 Hatch in the cargo area only.
Daily hack:
Deck: Alpine CDA-9886
Front sounds: RF T152 5.25" coax x2
Front power: RF Power T400.2
Subs: Alpine SWR-1021d x4
Sub power: RF Power T20001
4.59cuft net 56" of port tuned to 32hz.
Work ute
Deck: Alpine iDA-X303
Speakers front: Stock
Speakers rear: None
Subs: Alpine type S SWS-1040
Amp: Alpine MRV-T320 x1 for woofer.
Box 1.42 cuft 39hz hidden under tray in blow thru design.
New ute to be much different.
Hmm Double post...
Damn slow internet here.
Systems:
Fun Car:
Daily hack:
Work ute
Speakers rear: None
I get lazy and forget at times...
Here joo go. it was at a soundoff a week ago, was beating on the truck a bit that day and batts where definitely drained
http://www.youtube.com/watch?v=e22nWKR63ZQ
And then after the show at the lube center my buddy works at that I havent seen in a while, had to get my free lube and let him here my setup since its been about a year.
He had his scoshe boomstick.. LOL
http://www.youtube.com/watch?v=u1UmH1DFYXY
and a lil cantrick
http://www.youtube.com/watch?v=b2FyY7dqhtk
Was that 3/4 volume? I still dont get the point? Unless you just listen to bass CD's all day, which I used to do... 15yrs ago... LOL
well as you seen many times in the video, its volume 24, on a alpine headunit that goes to volume 35, but anything passed 24 the preouts clip...
This box peaks at 36hz, but has a very flat response from about 22hz-51hz and is only about 1.6db change.
I listen to rap, and other music that Decaf or BigPimpin91 have re done.
Does it sound like Im listening to a bass cd? I played 1 song from a bass cd which was bass ballin.
Last time I checked Young Jeezy, or ronald mack was not considered bass cd material.
I dont think its all that bad since my full size suv, non walled, and tuned low will post over a 151db from two 18s and a single saz-4500. I could be wrong tho.
Hell no that ain't bad!!! Beautiful ride btw!!!
So, you're in SS 1/2? You gonna be there next year too? Thats hella flat response there man. :good:
I was just curious, because how much music is actually that low, unless its chopped... That was my whole point in posting here...
Yep, you could be wrong... :lol:
does running an epicenter count? I noticed that too, not much music goes that low and I run my epicenter alot....
Im actually in extreme os 1-2 because I have 3 alternators. :angry: And unfortunatly Wayne Harris is more interested in buying gas for his only airplane since he had to sell the 2nd one due to the econemy.... Instead of making proper rule changes to keep competitors happy and not leaving DBDRA for another organization. Because, again... my daily driven extreme vehicle with that uber thick 3 inch windows, and 10tons of concrete inside and a modified interior dont belong in a extreme class of any sort. BUT I could run SS1-2 with my truck off, and fully defeat the purpose of striving to keep my amps happy with voltage & amperage..... Hmm if that aint fair... I might as well run a Street class against a CRX that will burp a 155 with a pair of 10s and 2000watts clamped...
I also run bassrace 149.9 or 139.9 if someone in that class has a cash bounty on them :)
Meca Driveby 5
Usaci StreetBeat 4
Usaci Modified 1001-2000
and on occasion port wars or modified port wars (depending on if the mic globe will fit in my port on whatever box Im using at the time).
  • Who's Online   0 Members, 0 Anonymous, 1751 Guests (See full list)
