class g/h amplifiers
baaudio
so im familiar with class a/b and class d. but i just saw today that the cerwin-vega stroker 2000.1 is a class g/h? whats the deal with these?
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
arc se4000
and many others have been using it for years
If I remember right they have lots of secondary taps on the transformers which give you loads of different rail voltages. Then it passes the load between rails as the output voltage rises. I think it's a bit more efficient and you can have a lot more secondary voltage capacitance but otherwise I can't remember why they do it...
10.x volts fo' life!
so what does that mean? sorry i suck with technical talk lol
Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward
The Revolution Was Not Televised
But There Is This Thread(clicky)
Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc
sound close to a/b, with the perks of current in D class
Class G amplifiers (which use "rail switching" to decrease power consumption and increase efficiency) are more efficient than Class AB amplifiers. These amplifiers provide several power rails at different voltages and switch between them as the signal output approaches each level. Thus, the amplifier increases efficiency by reducing the wasted power at the output transistors. Class G amplifiers are more efficient than Class AB but less efficient when compared to Class D, without the negative EMI effects of Class D.
That what info i found about those types of amps. cause im like you i haven't heard of them before
Build in progress
Alpine CDEHD-138BT
Alpine SPX-17PRO 2x
Alpine SWS-15d2 2x
Alpine PDX-V9 2x
Alpine PDX-M12
Stinger SPC5050
Stinger 1/0ga and 4ga
Audioquest interconnects and Speaker wire
Dynomat 10455 mega bulk pak
Dynomat 1/8 and 1/4 liner
All that in a Reg cab truck and it wont be a blow though
Class H amplifiers take the idea of Class G one step further creating an infinitely variable supply rail. This is done by modulating the supply rails so that the rails are only a few volts larger than the output signal at any given time. The output stage operates at its maximum efficiency all the time. Switched-mode power supplies can be used to create the tracking rails. Significant efficiency gains can be achieved but with the drawback of more complicated supply design and reduced THD performance.
idk what the advantage would be of an g/h amp
Build in progress
Alpine CDEHD-138BT
Alpine SPX-17PRO 2x
Alpine SWS-15d2 2x
Alpine PDX-V9 2x
Alpine PDX-M12
Stinger SPC5050
*cough* wikipedia *cough*
I'm guessing that most of these are mainly used to sell stuff. I'm sure that the specs are so close that you are better off going for class A/B or class D, depending on what you need.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
  • Who's Online   0 Members, 0 Anonymous, 1024 Guests (See full list)
