97' Ranger Blow Through (Rebuild Pg 6/7)
Mine has metal teeth also, but once you take it off once, it never grabs the same, also if your spray foam on it, when the foam shrinks a bit, it pulls the boot off the metal.
2004 Yellow F150 STX 4x4 Single Cab
2 Yellow DC Power 270SP's Alts
4(and counting) XS Power 6500's
4 DD3515s Supercharged
53cu.ft 4th order blowthrough
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
154.1 @ 41hz Legal Burp
Build Log
I wouldn't use the window sealant it'll be a biatch if you ever have to change the seal. I just use regular clear silicone on all the edges then lock the metal clip down over the silicone. That way if the seal ever needs replaced it'll come off fairly easy.
2007 Scion Tc- T1500.1bdcp & t600.4, Three P3D212's Ported at 40hz, T2 6.5" Components, Rockford Marine 8" coax's. Kinetik khc1400 in back, Kicker 0 gauge
1999 Cherokee- Rockford Prime Amps 300.4 & 500.1,Big 3, Rockford 6.5"Comp.s and 6.5" 2ways, 2 12" P2's Ported basic winter beater
2002 Mustang Convt.-T1500.1bd & 400.4, 3 P3D210's IB, JBL components all the way around,Rockford 4 gauge, Big 3, Kinetik khc800 in back
i never put anything on mine and it only leaks slightly while bumping in the rain. other wise it's cool.
Your hole is going to be huge and your going to need something to stiffen back up your wall under the window. like a metal bar like i used.
i like your design. good luck with it. i'm tuned in. :drink40:
JVC AVX-44 and 360.2
Subs: 2 RF T1 12s 1ohm mono off a RF T1500bdcp 80hz \/ in a 2.3cube 45hz slot port
Mids: 2 O2 8's off a Punch 550.2 behind seat, 2 Image Cxs 6.5's and 2 ID XS 6x9s 80-3khz in doors on a T600.2
Highs: 2 ID CD.1 MH HLCD 8ohm off a RF 400.4 3khz /\
We've discussed that about bracing. Got a welder so not the end of the world just won't know until we do it. Saturday evening or late night I should have pics up or might update through the day Saturday weather determining. Actually we will be out in the rain if that's the case. Lol
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
Looking good man looking good.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
