SMD/LVL 5 Warhorse F150. 10/18 new XS POWER
that makes absolutely NO SENSE....why not elaborate
ive seen quite a few examples of drop in tests that just either kept increasing or decreasing in score.
my friend Ric who works on the Geo Metro (DD Beast) had a powerbass sub in a box and used the same power back to back...hit a 149.x changed to a DD9515 152.x changed to a DDZ 154.x (something along those lines) and your saying its POINTLESS?? thats the difference between a win and a loss at a competition. you just gotta be the nay sayer and go against something for absolutely no reason
Steve Footz had 2 DD Zs and did a direct swap and drop in test fresh out of the box with 2 DC Level 5s and automatically went up .5 db
wheres the pointless in that...
my friend Jerome is coming to pick up the BTL sometime soon...were gonna do a drop in test with his BTL and the one im giving him in my box just to see what she does (granted its a 1 ohm and my lvl 5 is a 1.4 ohm) we just wanna see the difference. so no there not pointless
I agree with Chode on this one. Saying that a drop in test is pointless is absurd. No 2 Subs are the same and they will all perform differently under the same conditions. I feel that this is the only fair way to do a direct comparison between the LVL 5 and SMD. If I were to build 2 separate enclosures for each sub based on what that subs want for airspace, port area and tuning, now that would make this test pointless. I also want to say that this box is being built for DAILY driving and not to be a one note wonder. I am doing this test to see what the direct swap difference is for daily driving. TL numbers on music and peak SPL will be taken into account.
I fully agree with the fact that this test is NOT pointless. In fact I think its a perfect way to settle the other thread with the LVL5 vs SMD bashing. CJ18 was looking for the right woofer for his application. He will be doing the tests in HIS application which makes it a very valid test. I'm looking forward to the results, not to show which sub is FTW, but which one actually works better in HIS application.
97 Maxima SE
Bunch of shit going in, check out the build
As much as I would like to probably not. I play minor league baseball for the Atlanta Braves and will be at Spring Training during SBN. If there is anyone from around me that is going to be going to Florida state finals in Gainesville let me know. I am going to try and have the truck ready for then but not going to get in a hurry and make a mistake.
Very cool. If oyu dont mind me asking what level do you play at? There was a point in time where I would have sold my soul to play pro ball. now im old and washed up and play slowpitch softball.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I played this year in AA in Jackson MS.
good luck ill be pulling for you. i just saw who your mgr was down there. NICE!
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
It's not absurd... I think he said its pointless, because each sub does different in different enclosures... So, unless you plan on building 15 different enclosures, and throwing the same amount of wattage over the RMS to each sub, its gonna be pointless... I mean if the RMS of the DC is 2000 watts, and your throwing 6,000 to it. And if the RMS is 3500 of the SMD then you need to throw 3x its RMS just like the DC, otherwise, it wont be fair and you'll have people crying like bitches about why their sub lost or didnt do as good...
I personally think the shit between these 2 subs is fucking stupid. They are both BEASTS, and you'll never convince me that one is better than the other...
very well said i can make a box and make ether sub "beat" each other depending on what sub i want to win its compairing apples and oranges both subs have differnt power handling like differnt size boxes and ports
i thought a guy like chode have been in audio long engough to know this guess not or your fan boyness is not letting you see clearly
anyways this just became the biggest troll thread ever
troll it up its all pointless and in bad taste if people belive your bias ass test and think sub a is better then sub b cause you did a drop in test
I also like the fact that the lvl 5 was designed for spl and smd was made for daily and to take the power for loonnng periods of time
So while doing this pointless test you should play each sub at full tilt for 5 hours each and see what sub last longer
anybody with some real audio exp. will tell you this is stupid and pointless
The lvl 5s are picky in my experience, and like a certain enclosure. dont get me wrong they are freakn beasts and i threw my back out loading them bishes. i hope you find out what works for you, i went from dd 9515s to lvl 5 18s to xl 18s the dds dropped lower than any but the xls fuckn blur my vision and make me see double, couldnt get my lvl 5s right and kept snappin neck joints. so imo if you got the money its trial an error and keep doing it till you find what you like
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I think you AA guys are getting scared that someone is gonna actually do a test between the 2 woofers and you're worried you'll get butt hurt when the level 5 outperforms the SMD. Probably with less power :)
apples to oranges .... So the smd is the apple, and the level 5 is the oranges? I like those odds ;)
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
