friend just told me something about wiring the second battery
what i did was hooked up 1/0 awg on positive and negative and had a 300 amp fuse on the positive side
people who have bought from me Team Bassick (ALPINE) Purplehaze nidus
head unit sony dsx-s310btx
subs 2 12 incriminator audio king of bass
subs amp incriminator audio 20.1
mids/highs
mids/highs amp incriminator audio 6.4
equalizer clarion
crossover interfire
alternator 1 mechman 240amp
battery's xs power 1 d2100 2 d3100
sky high car audio 1/0 awg ofc wires
memphis car audio 1/0 ofc
xs power xs flex 4 awg
sky high car audio 8 gauge ofc
sky high car audio 12 gauge ofc
t spec rca
check out my building log http://www.stevemead...frey-build-log/
http://www.stevemead...d-other-things/
check out audio gear i have for sale
http://www.stevemead...51#entry1595151
yey one time when we had 2 12s and a 7k and a kinetik 2400 in a 4 runner and someone drove the car like a hot rod and snapped the positive wire off the ring terminal and almost broke the rca imputes on the amp thank god we where using a 300 amp fuse on the positive side
mids/highs
equalizer clarion
crossover interfire
t spec rca
I have money for fuses... and if your car burns down that's what insurance is for.... if it did burn down ide get cashed out for more then I ever dreamed of putting into my system, full retail on my equipment...
You'd get cashed out for exactly $fuck-all because you didn't have fuses, so they will turn down your claim.
Your original post was both ignorant and irresponsible.
10.x volts fo' life!
x2
I dont even know why we're paying him any mind...
We already know his personality blows from his other thread....
DAT 4125------>RE XXX comps active
Eclipse cd7000
I serve drunks for a living :D
ABSOLUTELY NO NEED FOR FUSES ANYWHERE IN YOUR CAR AUDIO SYSTEM….. ADDS RESISTENCE, AND WASTE OF MONEY!
Been doing this for over 5 yrs and have never ever used fuses.... unless your shit is gonna ground out somwhere in your + lines then you should rethink where you run your power cables....
And SURELY no need for 4 damn fuses for one run of wire to the second batterys LMFAO!!!!
You know while your going fuse happy, fuse the + wires that run from your amp to your subs....
Seriously?
If there are no need for fuses in your car why would the Manufacturer even put any in there? Why would Amp companies put fuses in amps?
That has to be the most retarded thing Ive EVER read.
Man.........
Fuses are cheap
Amps are not
cars don't like fire
This is an easy answer, Use fuses or bring marshmellows to roast over the car fire while you wait on the side of the road watching your ride burn to the ground
I've seen first hand what happens with insufficient fusing. buddy's Prelude hit a pothole and because he half-assed his install a power wire came loose and started a fire. We had a nice flame going while we waited for the proper authorities.
Alpine F1 Status
DD CS6.5 x2 Front Stage
DD 9512H
DD M4a @ 2 ohm
DD S2b @ 8 ohm per channel
I run high ohn loads for MASSIVE headroom and cleaner SQ
270amp alt
D2400 up front
D3100 x2 batter in back
In elvis's defence he's around a lot of db dragers and almost all of them do not use fues's in my comp car I don't as well so maybe us talking down fueses in comp he took to daily but I do run fueses in any daily set up just not in comp set ups
But you better belive I got the wire cutters handy I have had a amp/car fire from no fuses I know the risks
Still for daily you need a fuse /thread
  • Who's Online   1 Member, 0 Anonymous, 1817 Guests (See full list)
